2 members (Southerntruck, Hush), 150 guests, and 2 robots.
Topics128,114
Posts1,056,287
Members48,439
#1509985 07/21/2023 2:27 PM
ladies and Gents,
I decided to tap out to the Texas heat and add air conditioning to my 51 3100. The vent windows blew hot air in my face like a drier vent.
As I read the instructions, it seems pretty straight forward. The question that I have is, does anyone who has done this know the belt size of the smaller pictured belt? It goes from alternator to condenser on a Vintage Air System.
If I find out more, I’ll post it! Time for research!
Engine: ‘61 261
Chris
Update: belt is 1/2” wide. Vintage Air can’t find the belt length. Their tech department is also researching.
B Online: Content
Set the alternator to the mid point in its adjustment. Steal your wife's (or mother's or grandmother's) cloth measuring tape. Try not to get grease on it while you are measuring around the belt path and head to FLAPS.
Hey Bill!
I pray it’s cooler up north in the hill country!
I was hoping that someone had already put one in and have the length. I have yet to mock it up so I can only guess as to the length. I am installing it early next week and I’m putting extra stuff aside so I don’t have to make 1,000 trips to the local FLAPS.
Moderator, Electrical Bay
I have the length for both of those, but not for Vintage Air systems. For Old Air it was 44" and 34" the short one going between alternator and compressor. I used Mitsuboshi belts...not Mitsubishi but a fine old company who specializes in fan belts. You can find them at hardware stores like ACE and I've had excellent luck with them.
~ Jon
Thanks John!
I figured from a rough guess about 24”. I guess I’m way off!
I’ll let everyone know, along with part numbers.
Chris
Maybe but I'm not certain of the size of the pulleys on your compressor and alternator...and that will have an impact on the length. Should give you a starting point, however. ACE has good prices on them...
https://www.acehardware.com/brands/mitsuboshi
~ Jon
I guess I’m going to wait until I get it installed!
Crusing in the Passing Lane
That doesn’t look like much belt wrap for both alternator and compressor!
Ed
Thanks Joe!
Ed, I’ll let you know. I’m guessing around 24” or so. I layed a string out next to the bracket to get a guesstimate. I’ll get the correct belt once I can measure on Tuesday.
Belts are 47” for compressor (46.5 would be better!), water pump, balancer
And
28” for compressor- alternator
Now to find them!
I will save you my new favorite words I have learned as it will require modifications due to a pusher fan up front!
Part numbers:
Duralast: 15280 and 15470 (not 1/2” width as I was wrong with width)
Chris
Riding in the Passing Lane
I'm with Ed. That doesn't look like a very good setup to me.
George
1972 Chevy c10 Cheyenne Super
George/Ed,
The belt will cover over 1/2 of the pulley. The current picture is not tightened, so it will be more. Once it’s fully installed, I will send another picture. It must work as I’ve seen other trucks down here in Texas running the same setup.
Chris
It will work...either that one or the Old Air Products (and actually I used an alternator/compressor bracket I got from Patrick Dykes quite a while back). If you think for any reason you need more coverage of any of the pulleys, you can add an adjustable idler pulley but you'll have to get some iron and an idler pulley and make it. I'd check at ACE Hardware for the belts. I got mine there and it was about 5 or 6 years ago.
~ Jon
B Online: Content
My 228 GMC has similar bracketry and belts. 40,000+ miles since the A/C was added and no problems with belts yet.
I’ve only run into one identified issue (so far). Because I have a pusher fan (please don’t judge!), the drier doesn’t fit correctly. I will have to modify position and bend new lines to fit. Otherwise, it hasn’t been too difficult, just time consuming!
Chris
