0 members (),
110
Mod | | | Forums66 Topics128,183 Posts1,057,264 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | I am curious how difficult it is to replace a broken clock spring in the hood latch. I see they can be purchased along with a couple other small springs as a rebuilt kid for around $22. Much cheaper than replacing the entire latch. Any experience in doing this or words of wisdom appreciated. Thanks. | | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | I had to fix one of these years ago...may have been a 1957 but I think it was the same latch design. The clock spring wasn't too bad. As I recall it resembled the thermostat spring or any similar type spring. There was a split shaft it fit into and then I recall having to use a pair of needle nosed pliers and a screwdriver to wrap it around and make it catch a hooked lever-like thing (and I know that won't make much sense but I don't have an image for you). Those other two springs were not too bad, either. They're on the other side of the latch and pretty self-explanatory when you get the thing out and look at it. The same spring kit has been around a while. The one I had was pretty loose-feeling overall. Didn't keep it from working but I recall thinking if I was serious about rebuilding it, I'd have tried to make the pivot points fit better. Good luck.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | | | |
