1 members (walter74), 75 guests, and 2 robots.
Topics128,049
Posts1,055,740
#150966 02/16/2007 2:18 AM
Apprentice
Apprentice
I have a 55 6400 with an Anthony Hydraulics hydraulic lift. The lift has its own frame.
My question: What's with the strip of wood between the lift frame and the truck frame?
Mine has been mostly gone for a while, so gone that I can hand turn all the bolts holding the two together.
Can I put a strip of metal in there and weld them together? Why or why not?
#150967 02/16/2007 4:02 AM
The wood allows the frame and bed to flex independently with out much squeaking or wearing of metal to metal.
If you weld them together the frame will not flex as it should, cracks will start to appear.
If you don't use wood, the steel will rub on the steel and wear and make noise.
The wood was, and still is, a good idea.
1952 Chevrolet 3800 pickup
---All pictures---
#150968 02/16/2007 5:54 PM
I've been wondering that myself. Thanks Grigg!
~Ron
#150969 02/17/2007 4:30 AM
Also, if you've got any rivet heads on the top side of the frame, you can countersink them into the wood so they don't interfere with the bed setting on the frame.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
