1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2020 Posts: 76 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 76 | Anyone have a source for the the 50" threaded rod that runs through front bed panel to connect the sides? I have found it sold with the panel but I do not need the panel. Thanks | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | You should be able to find a piece of 5/16" (or maybe it's 3/8" - sorry I can't measure it right now.) steel rod at a local hardware and thread both ends.
Or give Mar-K a call and see if they'll sell you the rod.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2020 Posts: 76 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 76 | Thanks klhansen...i just looked up the rod and tools at my local home improvement store..didn't realize how inexpensive the tools and rod were. | | | | | Joined: Oct 2021 Posts: 6,688 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,688 | Home Depot, etc sell threaded rod as well. Does it have to be a rod with threads on each end only? What would be the difference?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2020 Posts: 76 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 76 | I bought fully threaded rod and a solid rod just in case when I cut the threaded rod and mess up the thread too much to start the nut I could try threading the ends on the solid. Just need to make sure I get the correct measurement. I think I saw 50" somewhere but I guess I will just put it together and take my own measurement. I do not see any installation methods in the book. | | | | | Joined: May 2016 Posts: 268 'Bolter | | 'Bolter Joined: May 2016 Posts: 268 | Put a couple nuts on the threaded rod before you cut to length then after cutting you can back them off to clean up any bad threads. 1949 gmc 1-ton | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Should be just a smidgen over 50" which is the inside width of an AD bed. Add 1/8" for the thickness of the two bed sides, the thickness of two flat washers and two lock washers, and 3 or 4 times the thickness of a nut. You should have a few threads sticking out each end after it's assembled.
