Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 557 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
#1509527 07/17/2023 3:23 PM
Anyone have a source for the the 50" threaded rod that runs through front bed panel to connect the sides?
I have found it sold with the panel but I do not need the panel.
You should be able to find a piece of 5/16" (or maybe it's 3/8" - sorry I can't measure it right now.) steel rod at a local hardware and thread both ends.
Or give Mar-K a call and see if they'll sell you the rod.
Thanks klhansen...i just looked up the rod and tools at my local home improvement store..didn't realize how inexpensive the tools and rod were.
For future reference and search engine I found it.
https://www.mar-k.com/partDetails.aspx?LID=1714
$63 shipping to Indiana....I will thread myself..thanks again
Home Depot, etc sell threaded rod as well. Does it have to be a rod with threads on each end only? What would be the difference?
1950 Chevrolet 3100 (Ol' Roy)
1939 Packard Standard Eight Coupe (The Phantom) | 1956 Cadillac Coupe de Ville (The Bismarck) | 1956 Cadillac Sixty Special Fleetwood (The Godfather) | 1966 Oldsmobile Toronado (The Purple Knif) | 1966 Ford Mustang (Little Red) | 1964 Ford Galaxie 500 coupe | 1979 Ford F-100 | 1976 Ford F-150 (Big Red) | 1995 Ford F-150 (Newt)
I bought fully threaded rod and a solid rod just in case when I cut the threaded rod and mess up the thread too much to start the nut I could try threading the ends on the solid. Just need to make sure I get the correct measurement. I think I saw 50" somewhere but I guess I will just put it together and take my own measurement. I do not see any installation methods in the book.
Put a couple nuts on the threaded rod before you cut to length then after cutting you can back them off to clean up any bad threads.
1949 gmc 1-ton
Should be just a smidgen over 50" which is the inside width of an AD bed. Add 1/8" for the thickness of the two bed sides, the thickness of two flat washers and two lock washers, and 3 or 4 times the thickness of a nut. You should have a few threads sticking out each end after it's assembled.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.054s Queries: 14 (0.050s) Memory: 0.6222 MB (Peak: 0.6926 MB) Data Comp: Zlib Server Time: 2025-09-22 07:22:33 UTC
Valid HTML 5 and Valid CSS
