7 members (klhansen, Otto Skorzeny, MickeyP, DadsFirstPickup, Woodcmiami, Hotrod Lincoln, Wayne67vert),
73
Mod | | | Forums66 Topics128,043 Posts1,055,609 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | Hello large truck friends. I am in the process of aligning my doors. I have the driver side adjusted nicly. Closes well, tight etc. The passenger on the otherhand is becoming a real pain. My hinges are good and tight, no wallowing in the bushings etc. My door latches are good, not all worn and clapped out. I have heard from some oldtimers that the cab gets "sprung" from hauling very heavy loads out of the fields. If thats so why does my driverside work so well? Or is this just some good old fashoned chatting folklore at the feed mill. Thanks for all responses in advance.
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I had to heat and bend the hinges on my 46 1/2 ton to get the doors to line up just right. sometimes it takes a little tweeking since there was no real adjustments on those old doors.
1946 Chevy Pickip
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Beewrangler, I would classify the 'sprung cab' theory as 'BEE-S'. As you questioned, how come one side and not the other. I have enclosed a link to "chuckthetruck's" site. He has a small drawing showing how to bend and tweek hinges to overcome specific alignment problems. I have followed them and my doors came out pretty good. It's a art, so don't get frustrated right off the bat. Good luck. http://www.chuckthetruck.com/page20.html Stuart | | | | | Joined: Jan 2007 Posts: 19 New Guy | | New Guy Joined: Jan 2007 Posts: 19 | Try this:
But a short length of 1X4 between the door and the cab down by the kick panel. GENTLY close the door on it. This will bend the door back up where it should be. | | | | | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | Beewrangler
I haven't had the cab spring out of shape, but the doors themselves certainly can.
Not meaning to state the obvious, but it's key to pin-point exactly where the actual fault(s) lie & work on them specifically, or you can spend hours of work in frustration, without progress.
Ken | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | wrangler, if it's the 46 yer havin trouble with, check the cab mounting blocks for deterioration and the springy rear ones for difference side to side and good luck avoiding that sudden hive collapse stuff Bill | | |
