1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#1227975 08/01/2017 6:18 PM
1951 3100
Having discussed, recently, the installing of door locks, on a 51, that use the turn down style exterior handles, I have a question.
Intent is to have a door lock on both doors. Drivers side, I have fabricated the new latch to work with the new door lock. Passenger side latch comes ready to accept the lock, although I have not installed the lock yet.
Question I have is this: Holding the new door lock in my hand, key facing vertical (think 12 o'clock position), it will turn left to 9 o'clock, stops there, but the key WILL NOT come out. If you turn the key the other way to 3 o'clock, it stops there, and the key WILL NOT come out. Go back to 12 o'clock, and you can remove the key. Shaft turns in tandem with the lock cylinder. Logic tells me this ain't working correctly. This make any sense?
Mike
Mike
1951 3100 5 window
Mike, I just went out to the garage and checked mine (1948 3100, but actually has a 1950 cab). What you described above. is exactly how my OE lock works, also. I would add though that rotating the key to 9:00 locks the door; rotating the key to 3:00 unlocks the door. The cylinder/key is always at 12:00 to insert or remove the key. Good luck. Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Cool deal, thank you sir.
You have the lock on your driver's side also?
Mike
Mike
1951 3100 5 window
Mike - Will you be able to provide pics on the driver side door? I am contemplating doing the same to my '50 and pics may help out.
Thanks in advance.
1950 3100 5 Window
http://imgur.com/a/DAVYB
Bruce W,
Check your PM.
Mike
Mike
1951 3100 5 window
Flatblu4748,
Another question.....you checked just the passenger side on your vehicle?
Reason I ask this, the factory designed latch, on the passenger side, will/does operate different than what I've come up with for making the driver's side latch work with a lock. The locking/unlocking is determined at the latch. The door lock shaft only turns. I'm still gonna make it work.
Mike
Mike
1951 3100 5 window
hey mike-
any chance you can send me some of those pics as well? tired of having to lock on one side only.....
'53 3100 on '93 S10 chassis- 4.3V6 +4L60e
'51 suburban TBD
Originally Posted by theKidd
hey mike-
Darn shame the pictures and info were not shared HERE rather than via PM's.
Is there a write up anywhere on adding the door lock to the driver's door? I have a 1950 Chevy COE I would like to do this mod to. I'm sure I could figure it out by looking at the passenger door latch assembly.
Marty
AD Addict & Tinkerer
Kades51 is still an active member on this site. Send him PM and ask if he could share with the community.
Phil
Project Journals
Stovebolt Gallery Forum
Authorized Pest
Authorized Pest
Marty,
Mike is still around and is quite active. Maybe he'll see this and respond in here. If not, why not PM him and ask him to post that info to share.
This is neat in that this is a very old thread. thumbs_up
~ Peggy M
1949 Chevrolet 3804
I too am interested in adding a key lock on the driver side of my '47. Here is an even older thread with a link to some pictures:
https://www.stovebolt.com/ubbthread...-drivers-side-door-lock.html#Post1072278
I noticed in this version of the mod Evan has the lock arm pivot in a different place than the passenger side, so the key slot location is not symmetrical.
The passenger latch mechanism has the lock arm sandwiched between 2 components. The driver side would have your add-on part above that area, but it could be lined up with the same key location.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Authorized Pest
Authorized Pest
I sent Mike a PM asking him to chime in .... wink
~ Peggy M
1949 Chevrolet 3804
