9 members (Hotrod Lincoln, Mike B, Chev4t6, cmayna, Chip O, Guitplayer, KCMongo, Wayne67vert, oldieoldie),
70
Mod | | | Forums66 Topics128,180 Posts1,057,153 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | My 1986 C10 has a tired 305, need to swap it out. I have available a 350 out of a 1992 Chevy pickup. I have not started anything yet, just researching the hurdles. What will be my biggest challenges? | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | That is a pretty simple swap. Just move over all the srock sensors and you will be fine.
You could use the stock fuel pump from the 92 or use a race pump with a regulator. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | The fuel pump was one of my concerns, it is in the gas tank of the '92. My 86 pump runs off the cam. | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | I like the Walbro GS392 as a pretty universal EFI pump. The TBI system on the 92 runs fairly low fuel pressure. I will look up what it is when I get the chance.
I believe there is a combination filter/pressure regulator you can buy as an off-the-shelf part for it. | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | As I recall, 1987 was the 1st year for TBI, perhaps parts could be canablized. Pump in tank(s), I believe the fuel pressure spec is 9 to 13 psi.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | As I recall, 1987 was the 1st year for TBI, perhaps parts could be canablized. Pump in tank(s), I believe the fuel pressure spec is 9 to 13 psi. This is correct. The spec is 9-13psi. The sending unit with the integrated pump and return line is larger on the fuel injected truck, so it won't fit directly into the older tanks. The 87 used the same tank shape as your 86, but with the larger hole for the fuel injection sender. The combination of a new spectra premium tank and a sender/fuel pump combo is under $200 from rockauto. I am not sure you could set anything else up for that price (other than a junkyard raid). | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | The combination of a new spectra premium tank and a sender/fuel pump combo is under $200 from rockauto. I am not sure you could set anything else up for that price (other than a junkyard raid). Is that $200 per tank? | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | The tank switch valve & dash switch is different for the TBI engine v.s. carb (1986) as I recall.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2019 Posts: 2,243 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,243 | I was assuming a single tank, my bad.
It was ~$80 each for the tank and sender/pump. I rounded to ballpark $200 for shipping and tax.
They don't appear to be marked L/R. Are the tanks symmetrical for those years?
You will need the later switch valve hat BC59 mentioned because the TBI version has a pressure regulator at the intake and a return line and the switch valve needs the extra ports. If you can't find the correct switch valve, the later (mid 90s) Ford unit is a good universal valve with return ports.
The dash switch might or might not be compatible. I will see if I can rustle up a wiring diagram for each of them. | | |
