| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2023 Posts: 82 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 82 | So, after fiddling with the carb a bit the choke cable wire broke at the very end of the shielding. Has anyone ever just replaced the wire and not the entire assembly? I was thinking of just using some piano wire and and running a new cable through the sleeve but need to measure it out and see what size it is. | | | | | Joined: Jan 2014 Posts: 3,689 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,689 | My hand throttle cable did that very thing so I bought a reproduction cable. My plan was to replace the entire thing, sheath and all but getting the old one removed under the dash got the best of me.
Ended up sliding the new cable into the old sheath from the dash side. It works. The new cable is a slightly larger diameter so it doesn’t move as freely as I’d like.
1951 3100
| | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | You can buy replacement choke cable assembly’s thru most vendors fairly reasonable. Here is one from Classic Parts. [LINK]
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Sep 2009 Posts: 5,909 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,909 | CBall,
There may be enough slack in your existing cable that you could trim back some of the shielding to expose the unbroken inner cable. Reposition the shielding/cable in the securing clamp on the carb after exposing the cable and reattach everything and you should have a functional choke control again.
If there isn't enough slack to do this, lots of vendors selling replacement choke cable assemblies.
Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Mar 2023 Posts: 82 'Bolter | | 'Bolter Joined: Mar 2023 Posts: 82 | I like the look of my original handle and the sheath (going for the original dirty farm truck look) which has led me to look down the path of just replacing the wire and reattaching it to the original choke handle. For now I am just using my throttle cable till I can repair the choke. | | | | | Joined: Jan 2014 Posts: 3,689 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,689 | I had the same concern. But the new knob doesn’t look out of place on my “dirty old farm truck dash”, as it turns out.
I’m sure with some creativity, you could affix old knob to new wire. Not sure exactly how off the top of my head.
1951 3100
| | | | | Joined: Jan 2002 Posts: 2,840 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,840 | Couple dirty farm thumb prints on the new knob will break it in. I agree with Gdads51, about there might be an extra amount of the sheathing which you could shorten ending up with too much cable wire, which would allow you to snip some of the cable wire away, hoping the damaged area would be part of snipped part.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
