3 members (rfs56trk, Otto Skorzeny, Cletus1950), 115 guests, and 2 robots.
Topics128,128
Posts1,056,666
Members48,450
#1508356 07/08/2023 4:46 PM
After many years I've decided to do major work on the engine. I started reviewing my old posts because I don't want to ask the same old questions again. I plan to remove the cylinders and head. Take measurements to see if I can just replace the rings, bearings and oil pump. I have a local machine shop I can take it to if needed but I was hoping to do this with it in the truck. Maybe I should just do it right and pull it out, take it to the shop and let him measure and get the parts I need?
As it is I don't know which engine it is. The 292 has the engine mounts in a different position I believe?
Glenn
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
My 53 chev 3/4 ton truck came with a 216ci engine, but after all these years it may have another year motor. Get all the numbers you can find, most on passenger side of block also there are numbers STAMPED on a small pad next to distributor. Post the numbers you find and others will come along to chime in. Best of luck
1946 1/2-Ton Chevy
Pictures of engine would help.
BC
1960 C60 pasture art
I will look back on my posts I believe I did post pictures but I could not make much out of them, like they were not complete.
I found my old posts and pictures. The engine mounts are directly across from each other, the engine mount is followed by the fuel pump then the oil filter. The lifter covers are about 4 1/2 inches tall. I am not sure if I can copy the pictures and paste here or not.
Some pictures.
That "45" in first and last pictures looks like a partial date code to me. There are probably one or two characters in front of the 45 that would reveal the complete casting date.
glennj3,
I went back and reviewed all your engine related posts to review what was checked before. As was finally noted in a previous response on the same topic, you need to fully expose the engine block casting code that is partially hidden behind your coil, plus clean off the layers of paint and oil/dirt to reveal the entire casting code number so we can help to identify exactly what you have. See the edited pics (blue arrows added) below that shows the coil that needs to be moved and the obstructed casting number.
The casting date code (partially hidden in your other pics) and the stamped serial number you provided (not pictured) are currently no help in identifying the engine without the full casting number.
Please take and post pictures of the fully cleaned/exposed engine block casting code, and the stamped Serial# pad so we can better help finally answer your question. If you can get the entire date casting codes (currently showing as ending in "134"), that would help too, but not essential. There should be at least 1 "letter" in front of those 3 digits.
Would love to be able to help find your answer so you can move on to the next step! thumbs_up
Dan
casting code location
~ Dan
1951 Chevy 3 window 3100
Thank you Dan. I have to go into a differential on the MGB, might need to order parts for it. Then move into the truck!
No worries sir!
We will be here when you can come back around and provide the needed pics. wink
Enjoy the rest of your weekend. thumbs_up
Dan
~ Dan
Thank you so much!
