6 members (TUTS 59, HandyAndy, dt235sd, Bill Hanlon, 2-Ton, Brian Moore), 109 guests, and 2 robots.
Topics128,060
Posts1,055,836
Members48,427
#150847 02/09/2007 3:50 PM
All, We have an old 261 on the farm that had a cracked head. I'm looking at buying a 1948 chevy 4400 that I believe has a 235 in it. Would the head from the earlier 235 work on the 261?
Thanks for the help.
Jon
1 Offline
I think there are some steam holes in the 261 top deck that are missing from the 235 head. Maybe there not needed?? I am sure someone here has a more definite answer than my I don't think so.
restoring a 1946 coe wrecker.
try the engine and driveline fourm.I've seen same things mentioned as 1916 but can't remmember the details
It depends on what kind of 235 it is. It has to be a '55-up 235, previous 235's had differant bolt patterns.
Paint & Body Shop moderator
Quote
If you post the head casting code, we should be able to tell you more about that head working on a 261.
