3 members (5cameo8, kbenz, crenwelge), 115 guests, and 3 robots.
Topics128,088
Posts1,056,373
Members48,442
I purchased through Classic Parts the proper rubber hose, (with fittings), to attach to the bottom of my 1950 Chevy 1500 gas tank. It appears that there is a fitting missing from the tank that will permit this hose to screw onto the tank. It appears from the original build manual that there is a fitting that I'm missing which would accommodate the aforementioned hose.
Do any of you "bolters" know where I can get the missing fitting or the modern equivalent?
Rocket man,
I believe this is the critter you seem to be after. You may also need the related flex-hose with pre-attached threaded fitting that mates up to this tank connector/shut-off valve unit (shown on the far right of the linked page).
Fuel tank connector/shut-off valve
EDIT - Looks like you said you already have the flex pipe with fittings. thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
Here is a picture of what you describe.
Keep in mind I cut and placed an in-line fuel filter in the flex hose that attaches to the petcock valve. No matter how clean you think your gas tank is the filter catches quite a bit .
Good luck.
Todd
1950 Chevy 3100
Thanks, Todd...I just ordered the petcock!
Thanks, Dan...I just ordered the petcock!
Just did this with my 1950. I added a metal carb filter between flex hose and shut off valve. I did not cut my hose. My gas tank is new but wanted to catch any future trash before fuel pump.
~ William Moore
1950 Chevy 3100
Truck Tuesday Reports
"Bringing 'OId Blue' Back to Life"
I added a filter like the one shown above. Easy to check for debris and to change when needed!
Ed
