2 members (NJC, greenie-reddy), 159 guests, and 4 robots.
Topics128,260
Posts1,058,287
Members48,485
#1483408 01/14/2023 11:37 AM
Hello, got some pine boards for 53 truck bed, what are other alternatives to use other than bed strips?
1953 with a 216
Luray #1483409 01/14/2023 12:24 PM
O Online: Content
Laminate it like a butcher block and install it in one piece?
1950 Chevrolet 3100 (Ol' Roy)
Luray #1483445 01/14/2023 6:45 PM
I have been looking at these as a potential option:
https://www.novausawood.com/hidden-deck-fasteners
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Fibonachu #1483451 01/14/2023 7:57 PM
Installing a single piece in a '53 bed would be a trick. You'd have to remove the front panel and slide the single piece in below the angle strips and then reinstall the front panel and cross sill. Expansion and contraction of the wood would be an issue.
Those might work, but you wouldn't be able to carry any sand in the bed. Unless your objective would be to spread that sand along the road. It would leak thru the cracks. wink
Mar-K has different options for the bed strips, including hidden fasteners. If you're looking to eliminate the bed strips altogether, you could fasten them with wood screws through the cross-sills from below, but you'd need some provision to allow the wood to expand and contract. It would likely expand and buckle or contract and crack. GM had a pretty good design for the wood installation in the first place. Many wood beds have lasted 60+ years.
Luray #1483485 01/14/2023 10:41 PM
When I haul sand, I generally throw a tarp down first to make it easier to clean out.
The bigger downside to the hidden fasteners (in my opinion) is that the bed strips give you something to slide pallets and such on without scraping up the wood.
Fibonachu #1483527 01/15/2023 3:09 AM
yes
Luray #1506677 06/24/2023 10:40 PM
The reason for the split is to allow space for the wood to expand and contract. I built a kitchen counter out of old bowling lane one time .Like really old stuff, and I figured it was well sealed and seasoned. Anyhow, I had screwed it from the bottom and my feet told me one day that I had broken screw heads on my floor. I called bologna on the expansion theory until I marked the underside of the countertop and rechecked it on humid days versus dry days. Biiiggg difference there, like almost 1/2". I m not saying that your pine would buckle like a used car salesman will when he has a mechanic for a customer, but I believe that I would experiment with clamping them together for a couple of weeks and seeing what they tell you.
Luray #1507361 06/30/2023 5:47 PM
Ping Pong table plywood with the metal strips on top. Mine is 30+ years old and still running strong.
Craig
