Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (carbking, GMCJammer51, 1 invisible), 224 guests, and 6 robots.
Topics128,284
Posts1,058,522
Members48,490
#1506870 06/26/2023 4:15 PM
What do we do about the speedo cable being too short to reach to the input port on the 700R4?
I have a '66 I6-250, I just installed a 700R4 in it. Cable is too short. Will an extension like the one listed below at Summit work in the old girl?
https://www.summitracing.com/parts/dak-130011
"The greatest use of life is to spend it on something that will outlast it" ~ William James
'25 Chevy Superior
'66 Chevy C10
'03 Chevy Silverado 1500 HD
Speedo cable housing threads are pretty much standard from one make to another. Why not just buy a cable/housing assembly for a long wheelbase truck of some sort that's a few inches longer than the one you have? That would probably be more reliable, and not much more costly than patching on what you have.
Ugh....makes sense. I just hate the thought of having to remove the cluster....maybe I won't have too. I guess I could just purchase a new one.
'25 Chevy Superior
'66 Chevy C10
1962 C10 with a 235 6cyl -- all of the drive train seems to be original.
Some of this story is in the Side Lot
Some people like a new truck. I liked the old ones.
7
7 Offline
I think every speedo cable I have had experience with is accessible/removable without removing the speedo. In fact I think in most cases you disconnect the cable at the speedo before you can pull the cluster out.
You do have to disconnect the speedo before you can pull the cluster, but I am not sure you can route the speedo cable with the cluster in place.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Riding in the Passing Lane
The steel housing cable is much easier to work with then the plastic ones most part stores sell.
George
1972 Chevy c10 Cheyenne Super
George
I'm looking for steel housing cables everywhere and I can't seem to find them
'25 Chevy Superior
'66 Chevy C10
Classic Parts has them in the catalog.
George
