1 members (Gray_Ghost), 72 guests, and 0 robots.
Topics128,050
Posts1,055,761
#1506885 06/26/2023 5:56 PM
I want to paint my COE Single Stage Urethane Seacrest green.
Went to my local PPG dealer and they say they can't do it in their Omni Plus. I was quoted over $800 a gallon for TCP Global. I call B.S. on that.
Has anyone have any MODERN Vendor paint codes for Seacrest Green?
I thought what I had would have made it easy for them. See attached.
Marty
Mesa, AZ
Marty - Go check out Jim Carters site . He has the Seacrest Green, just not in urethane....
I've used his acrylic enamel paint with no issues. Single stage and you'll love the price.
https://oldchevytrucks.com/pt411g.html
Ron - - Dusty53
1954 Chevy 3604
Thanks, I was aware of Jim Carter's site and the fact he sells it in Acrylic Enamel.
I just got back from my Local NAPA store, who also sells Martin Senour Paint (by Sherwin Williams I found out) and they were able to pull up the Martin Senour 286 paint code from that sheet. For them it comes up as "dark green". So, he mixed up a small sample and it looked very much like Seacrest Green to me. So I ordered a gallon. The Martin Senour formula for single stage urethan is attached for anyone else that might want to use it. Ask they mix a sample batch for you so you can see it. At least my store would.
Hey that's great! Thanks for sharing the data.
Ron - - Dusty53
1954 Chevy 3604
Originally Posted by MNSmith
Yes, thanks. I was able to get it from my local NAPA for less.
PPG has a acrolic enamel product called alk200 which I believe is what Jim Carter uses. if you have a sample color of the paint they can probably match the color for you.
Mike
1940 Chevy 1/2 Ton presently... Almost done
1940 Chevy Business Coupe... In pieces
