Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (Steelonsteel, joetravjr, klhansen, mick53, Guitplayer, 1 invisible), 572 guests, and 1 robot.
Topics126,780
Posts1,039,294
Members48,100
Most Online2,175
Jul 21st, 2025
Y
Y Offline
I know What it is, and I have a good idea that it connects to the 3 vac hoses dangling underneath the drivers side of the cab...but why was it on the passenger side floor?
I guess my questions is...what do I need to know about this thing, and, since it was removed, I assuming that something's wrong with it. Are they repairable/rebuildable? On line source?
It says Midland 30J308 or 300308
what you need to know is with hoses dangling, you've got no brakes!
hydrovac brake booster kits - maybe available locally too
Yasmar,
Although I'm all for rebuilding most things, your old rusty Hydrovac would make a wonderful core for a factory rebuilt one purchased from your local supply house.
The Midland numbers should pin it down for the guys at the counter with the purple hair and pierced noses. smile
Stuart
Y
Y Offline
So which one do I need? It's just a seal and gasket kinda thing?
I think Stuart is suggesting that the entire unit could be replaced with a rebuilt one, and that the old one could be turned in as an exchange, or core. It may a lot less hassle than trying to rebuild yours. Personally, I've never dealt with one of these, so I have no idea.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
There is a Tech Article on rebuilding the hydro vac unit in the tech page.
The article deals with single vac units but I think the approach will be similar for the two stage units.
The parts are available or as has been suggested you may want to opt for a rebuilt unit.
Also the shop manual has instructions for rebuilding with excellent parts breakdown.
Hobert
"The Lord is my shepherd"
In St. Louis, we have a nearby Precision Rebuilders, which rebuilds components of medium and heavy- duty trucks, such as air compressors, air cylinders, and yes, hydrovacs. They supply most of the local truck shops with remanufactured parts, but I understand they will work directly with customers as well.
Check out their catalogs online at
http://www.precisionrebuilders.com/
and see if you find your hydrovac unit. If so, you can swap it out wth one slightly less "experienced". ;-)
Good luck, and please post with your results.
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Y
Y Offline
Upon further examination, the other side has a rust-thru issue.
What are my options as far as replacements. Does it have to be an exact replacement, or just one that's the same size? What do these normally cost?
V
V Offline
I suggest you take it to NAPA store with the numbers. They will most likely find one for you. I did it and they had one for my truck. Good luck!
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.049s Queries: 13 (0.046s) Memory: 0.6351 MB (Peak: 0.7093 MB) Data Comp: Zlib Server Time: 2025-09-22 19:21:10 UTC
Valid HTML 5 and Valid CSS
