2 members (Gdads51, Jon G),
147
0
Mod | | | Forums66 Topics128,198 Posts1,057,272 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 65 'Bolter | | 'Bolter Joined: Dec 2015 Posts: 65 | On my 1950 1/2 ton there are no door hinge springs to keep the door open. I have done the search and I am confused whether the door needs to be removed and which spring is for the upper or lower on the top hinge. There were non present on my truck, only a broken piece of one in the hinge area. I have the kit, my doors fit good and shut good.How difficult is this for those who have done it? I have printed the tech artical on doing this.Truck has been sitting since 1992, but never has a screw been hard to screw out, lucky I guess. As one said in the search that not having them present is driving him crazy, me too. I am working on the interior and use a 4x4 block to hold the door open. Never fails that I try to shut the door without removing the wood block from the jamb. | | | | | Joined: Sep 2009 Posts: 6,024 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,024 | Shof, I have moved your post to the Paint and Body Shop as it's the best forum for further discussion on your topic. Very sure you will get some great response and helpful info on your predicament soon.  Dan Note: The Moderator may move this further to the "Paint and Body Shop" sub-forum for "Doors" if it may fit better in there.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Nov 2021 Posts: 1,404 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,404 | I had broken springs on my door hinges as well. You need to remove the door hinge to rehab the pivot pin and replace the spring which means removing the doors. The spring goes on the top side of the top hinge. You need to remove the pivot pin to install the spring so it is a good opportunity to rehab the pivot. Its not hard but it can be a fair amount of effort to remove the door, get the pivot pin out, etc. With the srping in place the door will stay open (no 4x4 required). | | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | Shof - There is a very good YouTube video by Jerry Kassis that might be helpful ( it helped me ) . Take a look. Jerry Kassis rebuilds AD Door Hinges.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: May 2015 Posts: 11,168 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,168 | When I rebuilt my door hinges, I needed to recondition the holes that the springs go in to keep them from falling out. Also the slot in the hinge cage needed to be re-formed as well to repair the wear.
As Jerry's video shows, there are TWO holdopen springs on each upper door hinge.
A trick to keep the doors aligned is to drill a 1/16 inch hole thru the door sheet metal into the hinge strap before removing them. When reinstalling, line up the hole with the back end of the drill bit. That assumes that the hinge pins aren't severely worn.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Jerry Kassis's video is awesome
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: May 2015 Posts: 11,168 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,168 | Jerry Kassis's video is awesome He's got others that are great as well. I used his video when I rebuilt my wing windows.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2015 Posts: 65 'Bolter | | 'Bolter Joined: Dec 2015 Posts: 65 | Thanks for all the replies and video links. The doors were taken off and the hold open springs installed. The door pins were not replaced as there was no movement or wear. I was the helper with my mechanic friend. We work on it on Tuesday, thus Truck Tuesday. Again luck was with us, no bolts were frozen. The 2 most difficult parts were getting the spring set and getting the door back on. The springs just took time with the hinge in a vice and using a clamp the get the spring set in the hole. The upper hinge attached to the door was giving us trouble in getting back in the pocket so we removed in from the door and bolted it to the body. I was hesitant because the door fit was excellent. We got the lower hinge in the pocket and then the upper into the door and bolted it up. Only a slight adjustment made by loosening bolts and lifting rear of door slightly to get a good fit. This is definitely a 2 man job, those doors are heavy. Total time was about 2.5 hours total for both doors. The second door was faster than the first from learning. My doors now stay open and no longer need the 4x4 wooden blocks. Thanks to all. | | |
