7 members (Wayne67vert, klhansen, WarEagle1, Peggy M, pauld, UtahYork, 1 invisible), 93 guests, and 4 robots.
Topics128,185
Posts1,057,290
Members48,467
Has anyone attempted this? The new trans crossmember basically sits in the same spot where the e-brake bracket/cantilever was located. I cant find anything on the internet and supplier has no input. Any help and/or photos would be greatly appreciated!
Since you will be removing the park brake crossmember, now is a good time to upgrade the park brake system to the all cable system that was in Chevy trucks from 1966-72. I have done this upgrade on my 1963 and 1965 C10 trucks and it’s really great. I did a DIY about the swap. All the parts are available from vendors.
Here’s the LINK. DIY all cable park brake upgrade
Lugnutz: I started collecting the parts for that conversion on my own without realizing you had a DIY.
What are you doing for the actuator? Did you keep the stock in-cab setup?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
Everything inside the cab is factory.
darn it. Never thought about this. More parts I didn't need, and more money to spend.............
1966 C-10 Step Side
"Augustus"
Engage in the DITY
or follow along in his
Project Journal
RLB Offline
Thanks Lugnutz. Re-installing to whole e brake system on my 66 is on the to-do list this summer. Since literally everything on my truck was bent, broken, worn out or rusted out, I'm sure your list will be very helpful. I've bookmarked it for easy access.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
To simplify things, I think Classic Industries sells every part you need. I do not know how they compare price wise, but it would be one stop shopping.
RLB Offline
HiPo
THANKS SO MUCH LUGNUTZ, my SC neighbor!!!!! That's exactly what I needed! Y'all take care!
I sent you a PM.
