| | | Forums66 Topics128,211 Posts1,057,471 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I might be blind, but it does not look like the metal/rubber pieces that seal the inside of the fender to the box vent area are available aftermarket? Mine are beyond trashed.
It looks like I can simply attach thin rubber with sheet metal screws/3m tape and then the cab. What do other people do? | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | It's a fairly large area to block off. Whole back of fender is open to the door jam without these pieces. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I used classicparts.com They have the filler panels and the seals. FRONT FENDER TO CAB MOUNTING PANEL and FRONT FENDER TO CAB SEALS. Maybe not purest, but I used rivets to attach the panels to fender prior to final install. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | I will check them out. I was looking the other day at it. Seems a piece of rubber belting could easily be cut to fit and placed in there. Probably better seal than what was there originally. | | | | | Joined: Feb 2023 Posts: 387 'Bolter | | 'Bolter Joined: Feb 2023 Posts: 387 | The original metal style are still available. I had to buy one side & had a used one for the other side . I used some leftover rubber from the inner fender welting for the rubber part. While I did use stainless wire for stapes the inner fenders , I glued the rubber to the rear fender seals. The original style clips that hold the metal pieces to the fenders are available as well. I can look back thru my receipts for suppliers, if you need them. | | |
