7 members (Hotrod Lincoln, mo2cyl, Woodcmiami, 66flea, DadsFirstPickup, 5 Window 9434, 1 invisible), 102 guests, and 3 robots.
Topics128,049
Posts1,055,662
#15022 06/02/2003 5:01 AM
Hi....Newbie here..just bought a 59 F/S,w/235, driver..Have been told I need to use a gas additive,because of the unleaded gas...Is that right? and if so, what do You suggest...Thanks in advance
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#15023 06/02/2003 5:37 AM
no, not necessary - I've put about 40,000mi on a 57 235 w/ unleaded, no probs, and have run lots of old 283's, 327's w/ unleaded - story is the valve seats may wear a bit faster being not-hardened, but nobody seems to think it really affects longevity - when ya get yer motor rebuilt, ask for hardened seats
and welcome to the garage, where yer every puzzle can be solved eventually!! grin
#15024 06/02/2003 5:43 AM
I agree with squeeze. I switched my 235 over to Chevron mid grade once leaded became no longer and have no problems.
Craig
#15025 06/02/2003 9:01 AM
Can you still get the lead replacement gas additive? I went looking for it about a year ago and couldn't find any.
And welcome to the board!
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
#15026 06/02/2003 1:23 PM
Thanks to ALL for the quick responses.
One less thing to have to worry about..I have another question, but maybe a new post would be in order....THANKS AGAIN
#15027 06/03/2003 12:15 AM
I will chime in with advice to use the additive. I've had experiences with valves burnt in engines that have not used the additive, but no problems with burnt exhaust valves when the additive has been used on a continuous basis. It doesn't cost much if you buy it at wal-mart in the big bottle.
Fred
52 3600
69 C-10
