2 members (fonz8261, Oswald), 157 guests, and 3 robots.
Topics128,125
Posts1,056,337
Members48,440
#1502083 05/25/2023 4:01 PM
I am changing the motor in my '41 1/2 ton PU to a 235. A suggestion was made to change the center section in rear end to a 54/55 to get an open driveline. Is this an easy swap? Does it work? if so, where can I get more info.
ronsway #1502105 05/25/2023 5:12 PM
Here's what I did. My '46 has a '61 261, original bell housing, T-5 trans, open drive line, diff gears are 3:08 (I know to high geared but it was free), donor rear end came from a '65 Chev truck, 6 lug.
If you do the center section swap you will need to change the pivot rear axle, cut off original rear axle brackets for solid mounts. Not a difficult swap.
Best of luck
1946 1/2-Ton Chevy
ronsway #1502153 05/25/2023 10:50 PM
I think Ronsway is interested in doing a bolt in swap without having to change or modify anything.
Is there a specific reason you wanted a driveshaft instead of a torque tube? If your stuff is working now, why change it.
All the original, non-rebuilt stuff on my truck has over 3000 miles on it since last October. 216, 3 spd, torque tube, rear end all do what they're supposed to do without any fuss.
1950 Chevrolet 3100 (Ol' Roy)
ronsway #1502159 05/25/2023 11:37 PM
The reason is that my current transmission is so bad from a previous rebuild that I can't rebuild it. Unless I can find a rebuildable transmission then any upgrade would have an open drive line. Also the shop I am getting my motor from has all the hardware including a tremec 5 speed. I would like to keep as original as possible plus I am more of a "bolt-on mechanic" than a fabricator.
ronsway #1502426 05/27/2023 4:38 PM
If I convert to a T5 transmission is there a simple way mount the pedals?
ronsway #1502451 05/27/2023 6:35 PM
Maybe the pedal bracket from an AD (47-55) truck could be mounted on the frame. I have a spare. PM me.
AD PEDAL BRACKET
ronsway #1502931 05/31/2023 5:13 AM
Keep the original bell housing along with pedal mounting bracket/clutch etc from the 41. The 235 will bolt right up to your bell housing. The attached pic of my 46, shows original bell housing, original pedals and mounting bracket and the necessary adapter plate which mates the original bell housing to the T-5. The 47 and later pedals and master wont fit your 41.
1946 1/2-Ton Chevy
