0 members (),
136
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | What am I looking at for bellhousings? AND, if I wanted to go modern transmission, what am I looking for in bellhousings?
I found a company that makes an adapter for the 302 to a modern automatic, but, with no way to motor mount the jimmy on the sides, I'll have to do a front/bellhousing mount. I don't want 3 points of mount, nor do I want a modern trans hanging off the back of the engine all by its lonesome. | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | What is your goal and which vehicle are you putting it in?
Not sure if it matters without digging deeper, but what year 302 also?
Auto or manual or do you care? | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | The engine is homeless at the moment. Trying to figure out if I have a boat anchor or not. It wouldn't be horrible if I built a Panel around it or, if I could find one, a Canopy Express.
The engine is pretty and all, but if you can't get that power to the rear wheels, what good is it.
I don't know what year the 302 is. It's early enough to be the front mount/bellhousing mount type.
Prefer auto these days but, again, trying to figure out if it is worth keeping or not. Personally, I'll drive anything. Just show me where to start it. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Thanks! I believe I had seen that thread. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Buffalo in WA makes an adapter to put a modern GM bellhousing on 302’s. Since GMC flywheel bolt patterns are different than Chevy, can get a Chevy flywheel and redrill mounting bolt holes between the Chevy ones. If one does not need OD, a GM bolt pattern NP 540 series 5 speed transmission works well with a 302. Normal driving use top 4 gears, granny avail@ble for starting with loads.
I put one in my ‘47.1 one ton with transfer case behind.
Ed
| | | | | Joined: Jan 2022 Posts: 2,457 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,457 | I'm not sure Buffalo is still in business. A friend sent him a check to get Buffalo's front disk brake kit about a year ago. After calling once a week or so for months, the voice mail announcement turned generic, sounding like he is no longer building parts. The good news is that he never cashed my friend's check. Too bad, as Buffalo was building quality parts for relatively low cost. His ad is still up on inliners international, the only place I've ever seen him advertise.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Ed,
How would the mounting of the engine/trans assembly work? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Most light weight trans. are designed to hang off the back of the bellhousing which puts the load on the bellhousing rubber mounts. That would mean using the front lower mount on the engine. Don’t want to have 4 side mounts, twists frame. One can always make up a mount for the rear on most trans if any bolts are there.
On my NP-540 series trans, the transfer case was used for the rear mount.
Ed
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Are you saying front, bellhousing AND trans mount? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Don’t need the trans mount.
Ed
