2 members (2-Ton, baldeagle), 81 guests, and 3 robots.
Topics128,097
Posts1,056,495
Members48,444
#1484587 01/22/2023 2:11 PM
Has anyone tried making an adapter plate to go from 7.25” 10 bolt to 11” 10 bolt to use modern 22.5” wheels? I’ve got adapters to convert the center hole, but just thought of this idea. I’ve seen adapter plates to change the number of bolts to adapt different wheels, I can’t see why this wouldn’t work.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
Crusing in the Passing Lane
One can get 10 on 8.750”, 22.5” wheels(60’s GMtrucks) which can be found, and redrill them to 10 on 7.25” plus center hole adapters. Left hand wheel in picture. Milling machine and rotary table required.
Ed
I have adapters for the hub. What kind of tools would a shop need to be able drill the holes accurately?
Milling machine and rotary table. If they don’t know what you are talking about, go somewhere else! Find a proper ‘torque plate’ to finish the job! Drill the holes slightly under size, then use a 1/64” oversized reamer to finish holes, since two flute drills do not drill a round hole.
Ed
Ed
Ed you have a picture of the finished product on the truck?
Before sandblast and powder coat, trial fitting with hub adapter.
Ed
I found a shop who says they do the remake of the rim all the time. But they cut the center out and replace it with the center from the right bolt pattern.
Thanks, Ed- - - -you just saved me some money on a project I'm starting. I've got a 10 lug small bolt pattern vacuum shift 2 speed axle, and some 10 lug 24.5" wheels off a road trailer. I'm building a doodlebug tractor with a Turbo 350, a crash box 4 speed, and that rear axle, powered by a Mercruiser 4 cylinder engine. I was considering using Farmall Cub rear wheels adapted to the rear end, but lug tread 18 wheeler tires will work just as well- - - -especially if I run tractor inner tubes and fill them with liquid. I could even run dual wheels if I wanted to.
Big Bolt Forum Moderator
where did you get the adapters for the center hole?
Mike
Lincoln do they call you the mad scientist everytime to walk into the parts store or your metal supply I would love to see pictures of that when its done haha
1967 Chevy c50 327 w/ sm465 5000Ib front 15k 2 speed rear w/ 22k springs, single axle, hydraulic brakes
Mike,
Adapters for hub to center hole were made in my shop, black oxide coated by shop in Denver.
Ed
Moderated
Moderated
Can you give me the name or number to that shop? Looking to change wheels if possible. Can't find anybody that wants to even change a split ring wheel.
Hood's Machine Shop Bolivar, MO 417-326-7818.
