7 members (Peggy M, joe apple, WICruiser, baldeagle, Bill Hanlon, dt235sd, Stovebolt48),
118
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | I just replaced my alternator because it was showing a discharge on the ammeter. It also had a bearing that was going bad and had started squealing. My ammeter would always show negative at first start, as soon as I accelerated the engine it would jump to the positive and after a few seconds level out to the mid point on the ammeter gauge. Now that I have changed the alternator I am still getting a slight discharge. It is showing 12 plus volts at the alternator and the battery. What am I missing here. It starts fine each time and the battery is fine. | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | Sorry guys the truck is a 58 Apache with a 235 12 volt system. | | | | | Joined: Jul 2000 Posts: 2,188 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,188 |
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | No this is a different issue. Before I went from a generator to an alternator. This time I am replacing a bad alternator. | | | | | Joined: Oct 2021 Posts: 6,707 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,707 | Your voltage regulator could be malfunctioning.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | "Alternator" covers a lot of territory. Can you be a little more specific about which one was involved in the conversion from generator to alternator? The most common one is an internally regulated Delco 10-SI, but there are others that have an externally mounted voltage regulator. The wiring and diagnosis procedures are totally different. Jerry
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | It is the 10-SI and it has the internal regulator. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Use a small blade screwdriver in the D-shaped hole in the back of the alternator housing to bypass the regulator. It should go to a minimum of 15 volts at 1500 engine RPM if the alternator is good. If the voltage goes up with the regulator bypassed, either return the alternator as defective, or put a new regulator in it. Jerry
| | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | Just solved my low voltage problem. I bought a new alternator from Orillys and discovered it was bad after having it tested at another store. swaped it out for another and it was bad only produced 12.5 volts. Picked up a third alternator and it was the same issue with the same voltage. Always showed a negative on the amp gauge. took it back and got a refund and went to Advance auto and purchased one from them, everything is right on point. Alternator is producing around 13.5 to 14 volts running. I am 74 years old and have replaced lots of parts over the years and this has never happened before. So beware guys, just because it is marked new does not mean a thing. | | | | | Joined: Aug 2018 Posts: 759 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 759 | Most rebuilt alternators are designed to work with an idiot light only, and will not work without either a light bulb, or a resistor simulating a light bulb. I learned this the hard way many years ago. It can drive you crazy. I'm not suggesting that was your problem. I'm just posting it in hope that it might help someone later down the road.
Mike Burns 1940 Chev 1/2 ton 1953 Chev 1/2 ton 1950 Studebaker Starlight Coupe 1947 Indian Chief 1943 Indian 741
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Most rebuilt alternators are designed to work with an idiot light only, and will not work without either a light bulb, or a resistor simulating a light bulb. I learned this the hard way many years ago. It can drive you crazy. I'm not suggesting that was your problem. I'm just posting it in hope that it might help someone later down the road. Mike, a little misleading there. When an alternator is "rebuilt", like say a 10si Delco, it is rebuilt to be a 10si Delco. Which will operate on an indicator or an ammeter/voltmeter or neither. 10si alternators were available with different outputs at idle and different max outputs. (12si,15si, 27si) But basically the same alternator. Some case size differences. At first they called the 10si a Delcotron Generator. 10si does not need a light or resistor to operate. An idicator light is very nice to have. Neither the light nor a resistor in the "key on" wire is for "kick starting" the alternator. Speaking solely about three wire 10si install.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | The "Delcotron" was a model 52D, produced from 1962 to 72, and used an external regulator. Jerry
| | | | | Joined: Oct 2021 Posts: 6,707 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,707 | GM tried to get people to use the term Delcotron as a generic term like "Kleenex" to refer to Alternating Current Generators.
Chrysler was using the term Alternator. Of course Alternator stuck and nobody ever walked into a parts store and asked for a Delcotron for anything.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The "Delcotron" was a model 52D, produced from 1962 to 72, and used an external regulator. Jerry As I said, Chevy referred to the 10si internally regulated, solid state, integrated circuit, System Integrated unit as a "Delcotron Generator" into the late 70's early 80's. Used the name on DN and others.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Mike Burns Have always overhauled my own delcotrons,would get a pile of "defective parts" put them in an alternator,take-off and work fine !! Over the years made my own test equipment,have a way to externally test regulators just shuck em thru there. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | When they "reman" these alts. & some other parts they take out the quality original equipment parts & put in cheap parts sold to reman companies in mass amounts. The quality is poor & the failure rate is heavy. I always did the GM alt. & starters myself. They are so plentiful you can cannibal some for parts.
George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Wrenchbender Ret. My local junkyard has kept my alternator inventory up in good shape so I have a place to get original goodies. Can find the right stuff to make a unit that will prime at reasonable RPM then charge at idle,while you get around,neat and simple. | | | | | Joined: Aug 2005 Posts: 124 6 heaven | | 6 heaven Joined: Aug 2005 Posts: 124 | Please tell us or describe what test equipment you have made up! Very interesting! | | |
