8 members (Southerntruck, Oswald, Millenimech, Otto Skorzeny, 3B, Wrenchman, Shade Baby, 1 invisible),
98
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,831 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | Hello. New to Big bolts & this group. Got a 1967 Chevy C-50 dump truck a couple of weeks ago. Drove her 100 miles to my location. Next day was sett'in to trouble shoot rear brakes & found that both U-bolts on driver side rear axle were snapped (one towards front/ other towards back). Actually one of the broken U-bolt is really a broken ear on the botom axle plate. Just barely made it back here that day. Ain't drive'in her `till that's fixed of course. After lots of cleaning the bottom of the plate, I think it reads #3765663. The truck has a 2 over 4, w/ air lines running into the pumpkin. The pumpkin housing has no bolts in the back. There's 12 hex bolts on the drive shaft side. Can anyone tell me what make/model (etc) the rear axle is? Thank you.
CFFC Don | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Hey Don, Welcome to the big boy toys. Where in PA you from? ~Ron | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you need a shop manual - there's corporate and eaton 2spd rears - they both seem to be electric shift, but the eaton is said to be an option for 60 series
Bill | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | No bolts in the rear of housing makes it a Timken (Rockwell) rear end..Those aren't air lines, you have a vacuum shift 2 spd..as for the broken U bolts, I would they might have gotten a little loose and the axle worked back and forth..There should be a model # on the plate as well as a name...
Geoff
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Jan 2007 Posts: 63 New Guy | | New Guy Joined: Jan 2007 Posts: 63 | The shop manual describes the "Drive Line Rear Axle (Corporation) 2 Speed". "Corporation" must be the "driveline type", Whereas; Timkin/ Rockwell obviously the manufacturer(s). Also; "vacuum" (not "air") is correct. Please correct me if I got any of that wrong. From looking closely at the axle plate's broken ear & U-bolts, it appears that 40 years of rust/ rot took it's toll (& probably loosening too). I learned that these plates' design are great for collecting dirt & water in top at the U-bolt areas. Definitely worth a periodic check & clean. Thanx. CFFC Don | | |
