3 members (Southerntruck, Hanks custodian, KEVINSKI), 123 guests, and 1 robot.
Topics128,162
Posts1,056,933
Members48,458
1946 2 ton with a 1954 235.
As the title says a new generator is being shipped to me.
I never had to remove and reinstall a generator pulley.
So my question is what do I need to know how to R & R the generator's pulley.
Thank you for your help.
Jeffrey
Jeffrey,
I have moved your post into The Electrical Bay as that is the best Tech Forum for your question.
AM sure that one or more of our folks will chime in here soon with some helpful info and pointers.
I did find an old conversation on the topic which seems to have the info you are seeking.
Unfortunately all those old picture links are no longer functioning, but the description should be helpful.
Let us know how it turns out. thumbs_up
Dan
~ Dan
1951 Chevy 3 window 3100
If you have an impact wrench, that's how to get the pulley off your old generator. Same for installing it on the new generator. I suppose you could grab the pulley with a giant pair of water pump pliers to get the nut off, but that would bugger up the pulley. Or you could pull each one apart and clamp the armature in a vice, but why do that when the impact wrench method works so well?
Thank you.
The vendor said to wrap an old fan belt around the pulley and squeeze it tight and use an impact wrench.
Jeffrey
If the old generator is still on the engine, that would make a fine holder instead of on the bench. Just squeeze that belt. That's if you can fit an impact in there.
With an impact wrench, you don't even need to hold the pulley. It'll likely just zip the nut right off. The shaft might spin a bit, but that's not a big deal.
