| | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | 1946 2 ton with a 1954 235. As the title says a new generator is being shipped to me. I never had to remove and reinstall a generator pulley. So my question is what do I need to know how to R & R the generator's pulley. Thank you for your help. Jeffrey
| | | | | Joined: Sep 2009 Posts: 5,886 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,886 | Jeffrey, I have moved your post into The Electrical Bay as that is the best Tech Forum for your question. AM sure that one or more of our folks will chime in here soon with some helpful info and pointers. I did find an old conversation on the topic which seems to have the info you are seeking. Unfortunately all those old picture links are no longer functioning, but the description should be helpful. Let us know how it turns out.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | If you have an impact wrench, that's how to get the pulley off your old generator. Same for installing it on the new generator. I suppose you could grab the pulley with a giant pair of water pump pliers to get the nut off, but that would bugger up the pulley. Or you could pull each one apart and clamp the armature in a vice, but why do that when the impact wrench method works so well?
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Thank you. The vendor said to wrap an old fan belt around the pulley and squeeze it tight and use an impact wrench. Jeffrey | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | If the old generator is still on the engine, that would make a fine holder instead of on the bench. Just squeeze that belt. That's if you can fit an impact in there. | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | With an impact wrench, you don't even need to hold the pulley. It'll likely just zip the nut right off. The shaft might spin a bit, but that's not a big deal.
