2 members (TexasA&M48Truck, Nick in Manitou), 124 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
#1500538 05/12/2023 2:12 AM
There were none in my 235 when disassembled but I believe the shop manual instructs to use them. Is there any new knowledge out there? Are they still considered necessary and needed?
Matthew 6:33
1952 Chevy 1/2-ton 3100
Late '55 235/SM420/torque tube 3.55
Dalton Highway survivor (using original 216)
www.truckwithaheart.com
H Online: Content
They're as "necessary" as windshield wipers on a duck's backside. The place we usually found them was at the bottom of an inch thick layer of sludge at the bottom of the oil pan. Save a little time and effort and toss them into the pan before you bolt it up, if you feel like they really need to be included in the rebuild. A properly torqued rod nut will not loosen up, whether or not it has a palnut added. One that's not torqued right won't stay together, even with the palnut added.
Thanks much, that's the answer I was hoping and expecting to hear. They can't even be torqued past about 8 ft lbs and attaching twelve of them to a furiously spinning crank doesn't seem like a good idea. headscratch But you know, it's in the book, so had to ask. thumbs_up
Matthew 6:33
Skooter We had plenty of those laying around at home where we never put them back on.
