2 members (Hotrod Lincoln, latroca52), 73 guests, and 5 robots.
Topics128,024
Posts1,055,395
Members48,422
#150041 01/08/2007 3:58 PM
I
Junior Member
Junior Member
I Offline
My hoist will lower all the way down to the last 18 inches. it is because I removed the grain beds. Is there an adjustment i can make or does it need cleaned? i greased the scissor parts. it is cable actuated going to a big pin. thanks
#150042 01/08/2007 5:10 PM
if it's not a double acting setup [power up/power down] it's not unusual that it won't close all the way with no weight on it
#150043 01/08/2007 5:43 PM
I
Junior Member
Junior Member
I Offline
thats ok, I just needed to know that,before i started taking things apart. if it ain't broke don't try to fix it. thanks! although someone has a saying around here that says if it ain't broke, break it and then fix it. maybe i'll change the hoses or something and boost the economy
#150044 01/08/2007 6:18 PM
You don't offer the body size but if the hoist frame isn't binding and is properly greased it should come down with the weight of the platform. Obviously longer heavier bodies will lower faster. Make sure the hinge is free and lubed as well.
p.s. - I was in Nashville a couple of years ago after many, many years. Gets bigger and nicer with age.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#150045 01/08/2007 7:35 PM
I
Junior Member
Junior Member
I Offline
it is a 12 foot bed. it may need raised and lowered a dozen times to get it to work again. i'll keep at it.
