7 members (texas46, Stovebolt48, Uncles51, Donf, spanky, Hotrod Lincoln, Southerntruck),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,022 Posts1,055,384 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 31 Junior Member | | Junior Member Joined: Nov 2006 Posts: 31 | My hoist will lower all the way down to the last 18 inches. it is because I removed the grain beds. Is there an adjustment i can make or does it need cleaned? i greased the scissor parts. it is cable actuated going to a big pin. thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if it's not a double acting setup [power up/power down] it's not unusual that it won't close all the way with no weight on it
Bill | | | | | Joined: Nov 2006 Posts: 31 Junior Member | | Junior Member Joined: Nov 2006 Posts: 31 | thats ok, I just needed to know that,before i started taking things apart. if it ain't broke don't try to fix it. thanks! although someone has a saying around here that says if it ain't broke, break it and then fix it. maybe i'll change the hoses or something and boost the economy | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | You don't offer the body size but if the hoist frame isn't binding and is properly greased it should come down with the weight of the platform. Obviously longer heavier bodies will lower faster. Make sure the hinge is free and lubed as well.
p.s. - I was in Nashville a couple of years ago after many, many years. Gets bigger and nicer with age. | | | | | Joined: Nov 2006 Posts: 31 Junior Member | | Junior Member Joined: Nov 2006 Posts: 31 | it is a 12 foot bed. it may need raised and lowered a dozen times to get it to work again. i'll keep at it. | | |
