| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | are there any sort of disc brake conversions for my '65 C60? either front or rear axle? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A friend of mine swapped entire axles front and rear in his truck with axles from a school bus with disk front and rear. I would look in to a swap like that. If you want to talk to him I could get you his phone number. Grigg | | | | | Joined: Dec 2006 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 63 | That would be cool....do you happen to know what kind of bus he pulled them from? and were the front and rear discs? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might want to look at mid-'90s and up Kodiak and Top Kick trucks. They have disk brakes on bothe ends, with a somewhat unusual dual disk on the rear.
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I don't know what bus, but it was a somewhat new school bus, probably early 90's. Disk front and rear. I have looked at some of the new big Chevy trucks, they have nice axles with disk front and rear. If you could get a good deal on a wrecked one that would probably work. You may want to take a tape measure and start measuring trucks you see with the brakes you want, even at the dealers lot. Check for spring pin center to center measurements and track width. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I am trying to stick with my 6 on 8 3/4" 22.5 wheels and have been looking for a front axle that will swap. I have found this bolt patern used on Anthey sweeper truck and some later model stepvans. both of these I looked at had huge 15 mabe 16" disc brakes and 22.5 wheels. | | |
