Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
has anyone checked that has a new ignition switch and key cylinder ,not only that the key turns the switch but any key that fits inside or screwdriver. Evidently the side bar on the new cylinder is not coming into contact with the new lock housing wall to stop it from turning. I have 4 of these...all act the same. Retired master locksmith.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
I ran into that a few years ago. I got them from one of the popular venders of Chevy truck parts in this area. When I took it back they brought more of them out of stock & we tried them. Every one was like that.
George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne Super In the Gallery Forum
All were bad from different vendors. It must be the lock housing itself. Not the key core cyl. I have 2 old ones here that are lockable. I`ll try one of the old key cyl. in the new lock housing today. But I fear it is the lock. All being the same.
I have had the same issue from a local vendor. As stated most of the suppliers get them from the same source. Wouldn't it be great to get parts that work? I have purchased good ones from Danchuk though. Fred
Yes, it was Classic Parts of America. I can't remember the brand name but it is on a lot of reproduction parts. I just put the one that was on there back on. I drove it about 3 years before I realized it was like that. This has been several years ago. They may have corrected it by now. At least a guy would think so.
George
Danchuk is the same. here are some pics I took. It looks like the lock housing inner wall is lacking what the originals had there for the side bar to catch. The circle blue is where it is short/lacking. Key also comes out in any position.
I am not sure how to rebuild/fix this. Maybe cannot be done. Taking away metal is Ok but this needs to be added to. The lock housing needs that pot metal there so there is pressure on the side bar so the key will not come out. I wonder why they made it this way. Id use my old one but after rewiring it needs all the spades on the back of the switch. Ign 1+2 etc. The other one I have that is old has ign 1 2 but no spring in the housing for starting. It is for a foot start .
What is the problem with your original cylinder? You can probably fix that one. Metal worn away? You might be able to repair it with epoxy.
I'd try to find a used lock cylinder if I were you.
1950 Chevrolet 3100 (Ol' Roy)
Key cylinder is fine. same as the old ones. The lock housing itself needs undoable work. An old lock housing might work. Like I said the 2 I have that are old don`t have what I need with the new wiring . thanks
Lots of possible choices and suppliers to choose from.
Dan
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Anyone know Seth . I`ve sent him a few emails about the switches. I got one of the bad switches from him and wanted to let him know about them. However I`ve not heard from him. Hoping he is OK.
Hadn't visited his web site myself before today and found he has an interesting selection of parts being offered. His FB page (linked in his web site) shows a whole lot more items available than are listed in the website "catalog" page. There is also a phone number listed on his FB page which you could use to try and reach out to him.
Hope you can find out more about the ignition switches and can maybe share with everyone as you can.
Dan
The switch in my 56 Nomad failed a couple years ago, while I was driving. I remember looking all over for a replacement and surprised they were not readily available. I finally took a chance from someone on eBay that said it was rebuilt. Fortunately it worked just fine. Harder and harder to get good parts for our classics these days! Good luck!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery 1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter
Ok, all these aftermarket switches are bad. I don`t see the reason why they are made that way other than theft in mind with the chinese. If the key comes out in the ON position, then its a popsicle stick ignition. Your truck/car is not safe.
Seth says he can not help me. He must have found something out he did not know. Beware... be safe. I wish I had better news. Most people would not know. But try a popsicle stick on your switch. If it turns then its not safe. A rebuilt old one with a new key core would work.
I am looking at remote security switches. Or hidden toggle switch. All in all ,thats not a good thing to have. In certain situations, that could turn tragic. I guess if they want it, they will get it. But I am not in favor of making it that easy.
How difficult is it to adapt an off the shelf ignition switch (one that actually works) to a TF truck? I'm assuming it's not straightforward otherwise we wouldn't have this discussion.
I concur not difficult and you should be using all the terminals for something. Just make sure you have acc and ignition/run terminals correct for what they want.
What are you going to do about the prohblem Guitplayer?
So you have to keep the new defective switch and put a hidden cutoff switch elsewhere?
