6 members (Hotrod Lincoln, 48ed56pam, Ponchogl, lumbersawyer, MickeyP, Bill Hanlon), 136 guests, and 2 robots.
Topics128,081
Posts1,056,073
Members48,434
#1498249 04/26/2023 2:51 PM
I have a later, full pressure 235 in my 57 GMC with an “848” head and upon initial startup there is no smoke out of the tailpipe until maybe about a mile down the road, then it smokes like mad for a bit and at a constant 50mph there is minimal smoke, noticeably more upon deceleration and after a few moments of idling it pours smoke!
I have not conducted a compression test yet but thought I would pill the collective wisdom here before digging in!!
Valve stem seals?
Thanks for any input guys!!
53farmtruck #1498250 04/26/2023 3:04 PM
H Online: Content
Probably loose intake valve guides, but also check the drain holes in the cylinder head. A bad sludge buildup can clog the drains sufficiently to make oil puddle around the valve guides. Valve stem seals don't fix worn out guides!
Thanks Jerry
Always the voice of reason/experience!!!
I bought a 261 for $200 and it is supposed to be getting delivered this weekend! Also, with an 848 head, could be an easy fix? But it never is.
53farmtruck #1498970 05/01/2023 6:55 PM
Just did a compression test
#1 110psi
#2 100psi
#3 125psi
#4 128psi
#5 138psi
#6 112psi
Not terrible, I’m really thinking the oil burning is a problem in the head, the 261 with an 848 head showed up Saturday night, degreased, stripped and buffed everything yesterday, New valve stem seals and gasket set is supposed to arrive tomorrow. All the exhaust valves have the slightest bit of “wiggle” in this new head but the intake valve “wiggle” while in the guides is barely perceptible
53farmtruck #1498975 05/01/2023 8:11 PM
Now I’m really curious how much better it will run when #1 & #2 intakes actually open!!
53farmtruck #1498983 05/01/2023 9:51 PM
Which engine had the bent pushrods???
~ Dan
1951 Chevy 3 window 3100
53farmtruck #1498984 05/01/2023 10:09 PM
I see you got the upgraded "pretzel" pushrods.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
53farmtruck #1498999 05/01/2023 11:11 PM
Ask HRL Jerry about drilling an 848 head for a 261. Needs coolant flow above and beyond that necessary for a 235.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
Gdads51 #1499037 05/02/2023 5:14 AM
The oil burning 235 has the bent pushrods
I’m using the 848 head from the 261 to swap out the 848 head on the 235
Jethro in Va #1499038 05/02/2023 5:15 AM
The 261 came with an 848 head
53farmtruck #1499048 05/02/2023 10:45 AM
Leo Offline
Moderator
Moderator
I think that was quite common with Canadian 261s.
53farmtruck #1499067 05/02/2023 12:12 PM
That's an interesting question. I'm guessing it would run a lot better.
So what happens within the cylinder during the intake stoke if the intake valve is stuck closed ( exhaust is already closed ) ? Does the cylinder attempt to pull air/ oil from the crankcase , compress it , and then kick it out into an extremely hot exhaust manifold on the exhaust stroke? Would that explain some of the "oil burning? Hoping someone ( Jerry ? ) would provide an answer. Turn this into a teachable moment for an old guy like me.
Ron - - Dusty53
1954 Chevy 3604
53farmtruck #1499348 05/03/2023 10:28 PM
I think you are really on to something with this, all that vacuum has to be satisfied somehow!! Judging on how wet #2 was with oil I think that might be exactly the case!!
Speaking of pulling the head…. As soon as I lifted it off the block I saw the telltale steam vents and thought “oh yay” followed by “oh crap” I immediately set to scraping off grease on the side of the block to reveal the “captains bars”! Yep my 235 is a 261! Another set back while I now await the only 261 head gasket in Canada to arrive from Orillia, Ontario!!!
The head has been completely torn down, valves and seats buffed clean on a brass wire wheel, new valve stem seals installed and reassembled.
God I hope this fixes the oil burning!!!
53farmtruck #1499350 05/03/2023 10:32 PM
O Online: Content
Those pistons sure are clean.
1950 Chevrolet 3100 (Ol' Roy)
53farmtruck #1499351 05/03/2023 10:33 PM
7
7 Offline
Those cylinders with valves not opening or in some cases with valves that are not seating will become oil pumps.
78buckshot #1499358 05/04/2023 12:34 AM
"oil pumps" - that is valuable information, thank you for the input.
Ron - - Dusty53
1954 Chevy 3604
53farmtruck #1499360 05/04/2023 12:43 AM
H Online: Content
Compression rings use the pressure of combustion to help seal them against the cylinder walls on engines that are actually burning fuel. Pulling a vacuum against a cylinder with a closed intake valve will definitely draw oil past the rings. If the 848 head was originally installed on a Canadian Pontiac 261, it will have the coolant holes drilled into the head to allow the flow of coolant past the siamese-cast cylinder pairs. There will be a total of six holes. The 261 head gasket is also different than the 235 because of the 3 3/4" bore size.
53farmtruck #1499374 05/04/2023 1:49 AM
Jerry , thank you for clarifying the drawing of oil past the rings in the case of a closed intake valve during the intake stroke. Good information to know and add to the knowledge base.
Ron - - Dusty53
1954 Chevy 3604
Here is a pic of the Canadian 1960 261 block next to a full pressure (Canadian) 235 block from 1953
You can see those little holes in the 261, I’ve heard them called steam vents, between cyls 1&2, 3&4, 5&6
53farmtruck #1499399 05/04/2023 4:26 AM
H Online: Content
Because of the larger bore size (3 3/4" VS 3 9/16") there is no room for coolant to flow between the three pairs of cylinders which are cast in a figure 8 shape (Siamesed). The same process is used on a Chevy small block 400 V8, with 4 1/8" bores. The coolant holes in the block and the head are there to let coolant flow up the sides of the cylinders instead of flowing between them. An 848 head for a 235 will bolt onto a 261 block, but unless the extra holes are drilled into the head, hot spots will develop where the siamesed cylinders meet.
53farmtruck #1499666 05/06/2023 2:16 AM
Well, after 2hrs of reassembly the 261 is alive and not appearing to burn oil!!! Downside is the starter has now packed it in!! Maybe too much of a workout conducting the compression test??
53farmtruck #1499678 05/06/2023 3:13 AM
Glad to hear about a possible cure on that oil burnin !
Anxious to hear the results after a test drive.
That “oil pump” situation is fascinating, if that’s what was causing it!
Hope you can get a new starter on there easily.
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
53farmtruck #1499679 05/06/2023 3:15 AM
O Online: Content
May just need brushes for your starter.
Don’t think that’ll help with the grinding
53farmtruck #1499819 05/07/2023 12:39 AM
O Online: Content
hahaha! probably not
