1 members (wilbur53),
92
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 66 New Guy | | New Guy Joined: Dec 2005 Posts: 66 | Before I post on the "Parts Wanted", I need to know what the piece of sheetmetal behind the grill, under and in front of the radiator is called. I've got the (original) Service Manual, but I'm wondering if there's such a thing as a "Parts Manual" for the '48 2t. Bolt. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | If you are talking the piece that suports the radiator that would be the core suport. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | splash pan prolly or gravel guard - what you want is the assembly manual, which should call out names and cover all series, but the part will be the same on any series
Bill | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | its called a lower radiator baffle. It keeps the dirt and weeds from being sucked up into the radiator core. It also support the bottom of the grill. On your truck it would have had a hole in it that a crank would have gone though, if one was man enough to try and hand start the engine. On the big trucks there hard to find as most rusted out in the center where the grill support attachs. Like the upper baffle, they will only fit a big truck. The smaller ones use a different size and bolt pattern on theres. | | |
