| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | I have had 2 task force truck 55-59 trucks that leaked water into the interior running board area. I bet I am not the only one. Is this just inherent for these trucks or is there a fix? | | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | Well welcome to the world of task force. It very inherent for this model especially where seals are gone. It will come in around the door, in from the cowl vent which runs down the sides. Kick panel leaks. Hinge areas on doors. Mine currenly has a drip with heavy rain in from the wiper shaft going in thru the outer sheet metal since a rubber piece went bad. Its the main reason the floors and runners on the these trucks are toast. Lots of guys that start modifying their trucks like putting in smoothies for the cowl. removing vents and sealing up the kick panels good and making sure the door rubber is good and tight can keep the water out. But you should keep a yearly eye on your seals and you can stay ahead of it. | | | | | Joined: Sep 2009 Posts: 5,775 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,775 | lcfman, I have moved your thread to the Paint and Body Shop for further conversation as it is the best place for your topic. Am sure folks will chime in more there soon with helpful advice.  Dan
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
