4 members (tclederman, klhansen, Shaffer's1950, NorCal52Suburban), 59 guests, and 1 robot.
Topics128,153
Posts1,056,849
Members48,456
About a year ago, I bought a used compressor from an estate sale. Members of this forum gave good advice (that it needed a bigger motor) since I quickly found out that the 1/2 hp motor on the compressor was not adequate. About three weeks ago I found a good condition used Craftsman 2 hp motor for a fair price. Today, with the help of Stovebolt member Craig Tutorow I was able to swap out the 1/2 hp 110V motor and install the used (new to me) Craftsman 2 hp 220 V motor. Electrical stuff may not be hard for some people, but for me it’s a challenge. With Tutorow’s guidance, I got everything hooked up just fine.
It still needs a shroud for the belt and a few other parts before I can say it’s ready for service.
Video
Some pictures of when it was 110V with a 1/2 HP motor.
Nice!
1946 GMC Project
"Back-in-the-day Restore"
Big Bolt Forum Moderator
sweet! I did the same thing, got a bigger motor, then put a bit bigger pulley on it so it spins the compressor a little faster. More CFM out of it than original!
Mike
FYI: I swapped out the original tank for a brand new (free to me) Ingersol Rand tank that was discarded and never used prior to my ownership. I saved it from going in the trash before it was discarded. I’ve installed 2 safety valves. This little compressor has oil in the crankcase which I probably need to change. What weight oil would be recommended? Straight 30 weight? Heavier?
30 weight should be fine. You should use specific compressor oil, which doesn't contain detergent additives. It's generally just mineral oil, although some compressor oils are synthetic.
7
7 Offline
Quincy has oil they market as Quin-Cip, I'm not a Harbor Freight shopper but they have some compressor oil. I bet Napa has something.
Lowes and Northern tools carry it to. I've been running synthetic compressor oil in mine for about 5 years.
Crusty Old Sarge
Crusty Old Sarge
Most compressors use a specific compressor oil as Kevin mentioned, some are lighter weight and have anti foaming agent added.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
Lugnutz I use non-detergent 30 w summer non-detergent 20w winter. Changing twice a year keeps good oil to your compressor full time.
Moderated by  MNSmith
