6 members (MRMEROTH11, FAST55, 1955 1 Series, Hotrod Lincoln, greenie-reddy, Otto Skorzeny), 127 guests, and 1 robot.
Topics128,051
Posts1,055,768
#149888 01/01/2007 12:50 AM
any thoughts on a rear mount gas tank no a 552
Never take a sleeping pill and a laxative at the time.[/i]
1955 Chevy 3100
More pix on Photobucket
#149889 01/01/2007 4:25 AM
I'd stick with the stock location, much less trouble. All these old tanks can be fixed, just changing to rear tank will interfere with other things like spare tire etc.
1946 1/2-Ton Chevy
#149890 01/02/2007 2:26 AM
Welcome bowtiedaddy,
I would agree that factory is the best way to avoid headaches. On the other hand, if you have the energy and no spare, then...why not? I would consider just having something made to your specs and fit it between the frame rails for protection....anyway, welcome to the stovebolt!
When I yield to Him, it's amazing how peaceful and enjoyable life is meant to be.
1947 Chevy COE
#149891 01/02/2007 2:39 AM
I've never seen any reason to move the tank, much better things to spend time and money on
#149892 01/03/2007 1:05 AM
Just installed the LMC Tank Kit to my 65 GMC build, and it just took about 1 1/2 hr to install and run new fuel line (steel) from the tank to the fuel pump. Didn't check on availibility for the 55, but I like the new tank instead of repaired one. Came with sender and straps.
You Learn more Listening than Talking
