| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | any thoughts on a rear mount gas tank no a 552 | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'd stick with the stock location, much less trouble. All these old tanks can be fixed, just changing to rear tank will interfere with other things like spare tire etc. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Welcome bowtiedaddy,
I would agree that factory is the best way to avoid headaches. On the other hand, if you have the energy and no spare, then...why not? I would consider just having something made to your specs and fit it between the frame rails for protection....anyway, welcome to the stovebolt! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I've never seen any reason to move the tank, much better things to spend time and money on
Bill | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Just installed the LMC Tank Kit to my 65 GMC build, and it just took about 1 1/2 hr to install and run new fuel line (steel) from the tank to the fuel pump. Didn't check on availibility for the 55, but I like the new tank instead of repaired one. Came with sender and straps.
You Learn more Listening than Talking
