1 members (Naturalthud), 110 guests, and 3 robots.
Topics128,135
Posts1,056,423
Members48,441
#1497839 04/23/2023 8:46 PM
I’m just starting to get some things straightened out in the cab of our new 3100, I have delete plate, but can’t see how it should attach. The plate came with the truck. I can make a clip of some sort to fix in the radio opening but I thought there would be a boughten part that is made for that. And my searching I haven’t come across it. We are still building a house so I don’t get much time on this truck yet but I want to keep it drivable until I actually start in to do restoration!
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Insomniac
Insomniac
We took the delete plate off when we painted the cab. I think we either broke the clips or lost them in the process. I drilled two holes in the plate and installed it with two cad plated screws. Used large washer and lock nut behind the dash.
(In my collection, I had some AN525 washer head screws that worked nicely)
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I am sure you could find a trim clip to fit without drilling holes.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Thanks, was your plate like this one?
I wasn’t sure if this is an aftermarket, or what.
~Charley
“Bud”
1954 GMC 3 ton 302
If you would like I could take mine off to see what the clips look like .
"The Journey"
Follow in the DITY
Ok, I was looking for something like this but wasn’t finding it.
I see the picture says trim clips for wide trim.
~Charley
“Bud”
1954 GMC 3 ton 302
I will take mine off and look it is the same but no logo .give me 10 min
"The Journey"
Follow in the DITY
Thanks Kevin, and check that chirp again!
~Charley
“Bud”
1954 GMC 3 ton 302
I must have had the same issue you had only years ago . I made up this .they slide into the back slots.
"The Journey"
Follow in the DITY
Just a piece of tin with a cut off bolt brazed to the tin
"The Journey"
Follow in the DITY
Beautiful job.
I love the simple directness of it!
My only wonder is which way up.
~Charley
“Bud”
1954 GMC 3 ton 302
I don’t think it matters .
"The Journey"
Follow in the DITY
O K , thanks for going to that trouble for me.
How did the test drive go on the squeak?
( wrong thread I realize)
~Charley
“Bud”
1954 GMC 3 ton 302
Originally Posted by Steelonsteel
Beautiful job.
Paint dripping over the back on the longer edge is a dead giveaway. Gravity doesn’t lie. 😉
Aha,good eye🧐
~Charley
“Bud”
1954 GMC 3 ton 302
My 2 cents. I used panel magnets for delete plate. Very strong. I do not think it will move. I do wish I had the bolt stud and nut method though.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system.
JB Weld..."I put that stuff on everything"
Insomniac
Insomniac
Double backed tape would probably do it too.
Gord 🇨🇦
I'd fab up a box of sorts where the radio was. Use magnets or Velcro etc for the delete plate so you can have access to your new hiding place, for registration papers, a couple wrenches, or whatever. Space in old trucks is valuable, use it. 🤔
Great idea ! Secret compartment.
Best reason for using magnets.
I wonder if anyone has done this?
But of course if they told, it wouldn’t be a secret anymore!
~Charley
“Bud”
1954 GMC 3 ton 302
On both my 54 trucks the plate was held on by two bent spring steel clips. They slide in from a gap in the center of the plate. When positioned correctly you push them into the holes on the dash. The material and the design of the clip hold the plate tight. One truck is Canadian the other was built in Los Angeles.
1954 Chevy 1300 engine 235 (1959)
1955 (first series) Chevy 3100 engine 261 (1957)
1927 (other brand) Model T- engine 327 (1968)
Thanks! I will look to see if I have any of those clips.
Quite obvious now that I’ve seen them!
I would probably assume them to be door panel attachment clips or some such,
if I saw them. So that sure answers my original question.
Thanks again!
~Charley
“Bud”
1954 GMC 3 ton 302
The one in my 54 3100 has clips in it. I’ll take a pic and edit it to my reply.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
Thanks, Doug. Nice view of those clips, and the shape of them.
I will try and see if they might be available as a replacement part…..
I’m contemplating fabricating something in the clip line for it, otherwise.
Or a concealed box as Glenn says.
By the way, the back of that delete plate. It looks amazingly caked up with something.
Was the truck used in a sorghum mill? 😉
~Charley
“Bud”
1954 GMC 3 ton 302
Moderated by  ndkid275, Phak1
