4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#1497530 04/22/2023 12:14 AM
Would like to find a new regulator for my 6v system on a 50 chev pu with a 235, I am overcharging to 10v and higher, any ideas? The regulator has no adjusting screws, bending tabs is the only method from my reading. Not confident with this or any method, maybe a new one would solve the problem
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
blanch53 #1497533 04/22/2023 12:24 AM
Have you done a search? I found lots in 1 minute of searching...
The big auction site has them as well as The Filling Station
https://store.fillingstation.com/detail/FS-398R/Chevrolet_19401954_6_VOLT_VOLTAGE_REGULATOR.html
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
blanch53 #1497550 04/22/2023 1:48 AM
What Mike B said.
I would stick with Delco Remy NOS.
I saw a few on E Pay. Not too bad on price either.
1950 Chevy 3100
blanch53 #1497558 04/22/2023 2:19 AM
There are two kinds of regulators- - - -"Delco" and "WRONG!". Send me a PM and I can walk you through a very simple diagnostic procedure to make sure the regulator is actually the problem. A short to ground on one of the wires can put the generator into full output, and swapping regulators won't help.
Hi Hot rod Lincoln, tried a PM but couldn't something about you being in a private message limit, I should mention that only when I rev the motor the voltage goes higher, on the dash ammeter its hard to tell but with a voltmeter at the engine I can read a minimum of 10 volts without messing my hairdo
blanch53 #1497571 04/22/2023 3:19 AM
I cleaned up my inbox- - - -try again!
