| | | Forums66 Topics128,021 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Would like to find a new regulator for my 6v system on a 50 chev pu with a 235, I am overcharging to 10v and higher, any ideas? The regulator has no adjusting screws, bending tabs is the only method from my reading. Not confident with this or any method, maybe a new one would solve the problem
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | What Mike B said. I would stick with Delco Remy NOS. I saw a few on E Pay. Not too bad on price either.
1950 Chevy 3100
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | There are two kinds of regulators- - - -"Delco" and "WRONG!". Send me a PM and I can walk you through a very simple diagnostic procedure to make sure the regulator is actually the problem. A short to ground on one of the wires can put the generator into full output, and swapping regulators won't help. Jerry
| | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Hi Hot rod Lincoln, tried a PM but couldn't something about you being in a private message limit, I should mention that only when I rev the motor the voltage goes higher, on the dash ammeter its hard to tell but with a voltmeter at the engine I can read a minimum of 10 volts without messing my hairdo
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | I cleaned up my inbox- - - -try again! Jerry
