0 members (), 44 guests, and 4 robots.
Topics128,077
Posts1,056,013
Members48,433
#1496752 04/16/2023 6:47 PM
Have a 54 power glide engine
Plugs in it are R43
Calls for ac 46-5
Reason for my question is it diesels when shut off
Compression 135-150
Plug gap was too wide
I re-gapped but thought I’d aak about the r43 plugs before I reinstall
Can’t find a heat chart on line
What technique do you use to set your ignition timing?
Deiseling after shut down is often caused by a too rich condition caused by a malfunctioning carburetor.
Power piston hanging up, or accelerator pump leak depending on what carb you have.
O Online: Content
Make sure your timing isn't too far advanced.
1950 Chevrolet 3100 (Ol' Roy)
H Online: Content
Dieseling during shutdown is caused by an idle speed that's too high. Adjust the carburetor correctly and the problem will go away. Mixture and/or ignition timing has very little to do with the problem. If it won't idle somewhere around 500 RPM, fix the carburetor or find the vacuum leak.
I think you guys are on the right track
Since I posted I’ve found
Vacuum advance won’t hold vacuum which would be lean BUT the carb is a mess I think
Leaks
Oozes gas from everywhere after shut off and accelerator pump quit working
I rebuilt but I think I’m losing my touch if I ever had one
Never checked timing as I thought it ran fine until I started driving more
Carter W1 carb
1112353 9G12 distributor
Any leads on reputable carb and distributor rebuilders and or sources for parts
Distributor also has a bit of side to side play
Mikes carb supplied the carb kit
Thank you
Jack Ryan #1496806 04/17/2023 12:31 AM
AD Addict & Tinkerer
One of our own, “carbking” owns “The Carburetor Shop”. He has the carb kit you need or contact him and he may be able to rebuild it for you. Here is a link to his website. http://www.thecarburetorshop.com/
Phil
Project Journals
Stovebolt Gallery Forum
Roger that
Thank you
