2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1496434 04/13/2023 9:10 PM
Custom Title
Custom Title
I'm putting a '68 drum/drum master cylinder in a '65 truck to upgrade the single circuit brakes. Which port on the '68 M/C goes to which axle?? Both reservoirs are the same size. Thanks in advance!
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
Southtowns27,
The below 1st screen shot shows the brake cylinder/hydraulic line circuits and corresponding connections taken from the 1967 Chevrolet Truck Engineering Book. Couldn't locate a 1968 version of the book, but a check of the May 1979 Chevrolet Master Parts Catalog (see 2nd screenshot) shows the same master cylinder was used for C10's from 1967-70.
The connection diagram would be the same for your '68 master cylinder as it is the same part for those year applications.
I would note that your '68 master cylinder was originally installed with a warning light switch assembly for the '67-'70 model years. That switch may or may not be needed for your '65 application. Hopefully someone else will chime in with more details or experience/knowledge.
Hope this info is helpful.
Dan
EDIT NOTE: I have submitted a flag to relocate this thread to either the Driveline or 60-66 Trucks forums as it doesn't fit into this forum.
Dual reservoir master cylinder and brake line diagram 1967-Chevrolet-Truck-Engineering.pdf.png (733.28 KB, 62 downloads)
Master cylinder line connection diagram
Last edited by Gdads51; 04/13/2023 10:10 PM. Reason: Edited to correct info about brake switch
~ Dan
1951 Chevy 3 window 3100
Authorized Pest
Authorized Pest
Southtowns27,
Gonna move this to Driveline as recommended.
~ Peggy M
1949 Chevrolet 3804
Custom Title
Custom Title
Thanks Dan! That's exactly what I needed!
49 Chevy 3600
65 Chevy K10
I installed one on my 1963 C10 when I still had drum/drum brakes. I made a video. Some parts of the video will not apply to your 1965 C10. As I recall, the 1965 brake pedal pushrod is longer than the 1963 pushrod.
I honestly don’t think it matters if the rear brakes use the front or rear port on the MC.
Dual MC upgrade C10 video
H Online: Content
Is the diameter of the dual circuit MC piston the same as the single line cylinder? If not, you'll be opening up a Pandora's box of potential problems, including some deadly dangerous ones.
