4 members (NJC, Oswald, 2 invisible), 132 guests, and 4 robots.
Topics128,081
Posts1,055,955
Members48,430
Need help to install the clutch fork spring clip. A 57 3100 with 235. Bell housing, pressure plate and clutch disc have been installed. The clip I removed when taking things apart looked bent so I bought new (2 just in case) from Eckler's. Tips on installing would be appreciated.
Normally the clutch fork is installed on the ball on the bellhousing before the clutch assembly is installed. You may be able
to snake it in there and pry it into place but not too likely. You might as well avoid the frustration and remove the clutch,
install the new spring in the fork, and snap it back in place. Then reinstall the clutch.
Fred
It was years ago for me but ,I did the same thing and I did get it in without removing anything .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
That retainer spring is an assembly aid- - - -once the linkage is installed and adjusted properly, whether or not the spring is there is a moot point. Save the new springs for the next clutch change. I've worked on dozens of throwout forks with the springs missing. There will be no effect on the function unless the linkage gets massively out of adjustment.
