2 members (porsche, MickeyP),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 12 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 12 | Need help to install the clutch fork spring clip. A 57 3100 with 235. Bell housing, pressure plate and clutch disc have been installed. The clip I removed when taking things apart looked bent so I bought new (2 just in case) from Eckler's. Tips on installing would be appreciated. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Normally the clutch fork is installed on the ball on the bellhousing before the clutch assembly is installed. You may be able to snake it in there and pry it into place but not too likely. You might as well avoid the frustration and remove the clutch, install the new spring in the fork, and snap it back in place. Then reinstall the clutch. Fred
| | | | | Joined: Sep 2010 Posts: 2,307 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,307 | It was years ago for me but ,I did the same thing and I did get it in without removing anything . | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | That retainer spring is an assembly aid- - - -once the linkage is installed and adjusted properly, whether or not the spring is there is a moot point. Save the new springs for the next clutch change. I've worked on dozens of throwout forks with the springs missing. There will be no effect on the function unless the linkage gets massively out of adjustment. Jerry
