| | | Forums66 Topics128,275 Posts1,058,439 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I’ve been chewing on how to do this. Paint experts, please advise.
Would it be better to paint the letters first, then the gate…
Or
Paint gate first, then the letters?
I have one of those aftermarket Chevrolet stickers that you can apply, but was thinking of using it as the masking tape for the paint process. The letters will be semi gloss black like my one ton.
| | | | | Joined: May 2015 Posts: 11,273 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,273 | I'm no paint expert, but I think what I'd do is use the stickers to mask it, painting the letter color first, then put the stickers on and painting the tailgate color. Then carefully peel the sticker off and then shoot some clear on to reduce the edge where the stickers were. That assumes the stickers can peel off without issue.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2021 Posts: 1,258 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,258 | | | | | | Joined: Oct 2021 Posts: 7,032 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,032 | I'd be afraid the stickers would pull off the paint.
What about leaving the stickers in place and clear coating over them?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I applied the stickers 6 years ago. My truck sits outside year round and they are holding up great. No clear coat on them. I just applied them to the newly painted tailgate. | | | | | Joined: Oct 2021 Posts: 7,032 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,032 | I applied the stickers 6 years ago. My truck sits outside year round and they are holding up great. No clear coat on them. I just applied them to the newly painted tailgate. I meant that Fox is considering using the stickers as masking tape. I would be afraid that when he peels them off, they would pull the paint off with them because, as you say, they adhere very well.
| | | | | Joined: Jan 2016 Posts: 1,110 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,110 | I agree about how well they adhere. I considered using the decal as a template for paint but they stick tight. I would not be easy removing them cleanly after painting. | | | | | Joined: Apr 2021 Posts: 427 'Bolter | | 'Bolter Joined: Apr 2021 Posts: 427 | I attempted to use the letters as a template and failed miserably. The letter part of the sticker is one thing but the residue it left behind made a mess. Ended up ditching the tailgate letters for now.
If I decide to revisit the idea, I’m going to put the sticker on and clear coat it or get a pinstriper to hand paint the logo. | | | | | Joined: Apr 2017 Posts: 230 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 230 | To prevent bleeding under the tape, brush over the tape edge with Clearcoat. The paint won’t be able to bleed under the tape. Pull the tape up and you should have a clean edge….. then clearcoat over the entire job. If using single stage, just use the base color instead of the clearcoat to seal the tape.
Mike
1940 Chevy 1/2 Ton presently... Almost done 1940 Chevy Business Coupe... In pieces
