1 members (GMCJammer51),
94
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,278 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2022 Posts: 13 'Bolter | | 'Bolter Joined: Oct 2022 Posts: 13 | Hello: Several months ago I installed drivers door window, vent, and regulator. Works great, window easily rolls up and down. Yesterday I did the same to the Passenger Door. The window is very tight. Very hard to roll up and down. The regulator is good and actuated freely. There does not seem to be any meaningful adjustment on these windows. Any ideas why drivers window works great but passenger side is very hard to operate? Ideas to correct this? Thanks. | | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | There is some adjustment on the bottom of the division bar between the vent window and the main window. The bolt is accessible thru the lower hinge access panel. Loosen it up and move the division bar forward a bit. You might have to loosen the vent window bolts as well.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Davegmc 1 If the above suggestion doesn't doesn't free it up,could have your local glass shop grind it down. Compre thickness too. | | | | | Joined: Nov 2020 Posts: 792 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 792 | I had a vent window ground by an auto glass shop recently with good results. It can be done. | | | | | Joined: Oct 2022 Posts: 13 'Bolter | | 'Bolter Joined: Oct 2022 Posts: 13 | Okay. Division bar adjustment used up. Glass shop technician said he can't sand it because it is tempered, will explode. He said if it was laminated glass (like the vent windows), no problem. He said to spray with silicone. I did that and it helped somewhat. I don't know. Drivers side works fine and all the parts are the same, glass, felt, etc. Guess I will just live with it. | | |
