2 members (Hotrod Lincoln, TexasA&M48Truck), 186 guests, and 1 robot.
Topics128,082
Posts1,055,964
Members48,430
#1494851 04/01/2023 8:25 PM
I'm having difficulty sourcing new pushrods for my '42 235 (casting 839931). The ones pulled measure 10.625" (269mm) x .24 (5mm), w/oil passage, ball end @ .47" (12mm), cup end @ .5" (13mm)...give or take, given the wear. I have searched Jim Carter, The Fillling Station, chevsofthe40s, Google general searches. Found a set of what I thought was correct on eBay, but those are going back.
I have a new set of the milk-can style lifters that are correct for the engine.
Any advice would be greatly appreaciated!
1942 1-1/2 ton flatbed
H Online: Content
Use pushrods for a 216, and put the adjuster lock nuts UNDER the rocker arms. The 235 block is 1/8" taller, and the short 216 pushrod will work, but there's not enough room to run the lock nut in its usual position.
These guys will build custom pushrods in any configuration you want:
www.pushrods.net
MDReed #1494879 04/02/2023 12:11 AM
Pushrod lengths
My Blog
panic #1494881 04/02/2023 12:24 AM
"w/oil passage" --- the pusrod is hollow, and both ends are drilled to pass oil through to the lifters and rockers. I'm not able to find anything but solid rods. Plus, the ball end diameter is crucial, so as to fit the lifters properly.
MDReed #1494884 04/02/2023 12:44 AM
H Online: Content
There's no oil supply gallery to the lifters, so tubular pushrods are a moot point. The first 235 with hydraulic lifters came out in 1950, in passenger cars with a Powerglide transmission. Those engines had solid pushrods, with a slot ground in the bottom pivot ball to allow air to purge itself out of the lifter. Trucks with 216 or 235 engines always had solid lifters, and solid pushrods, so your tubular ones can't be original. Does your rocker arm shaft have an oil line plumbed to the connector at the center of the cylinder head?
Jerry, this is good stuff! To the best of our knowledge, this is the first time the engine has been overhauled; the sludge throughout was attrocious, as was the wear. I do know the head was cleaned and surfaced back in the early 2000's, after the truck sat abandoned in an orchard for many, many years. The rocker arm assys are currently out being rebuilt, but looking at pictures I took during disassembly, it does have a single oil lined plumbed in the center.
H Online: Content
OK- - - -you can use solid pushrods of the correct length, or the slightly shorter, but more easily acquired 216 pushrods by the work-around I mentioned of putting the lock nuts on the underside of the rocker arms. The website I linked can fabricate new pushrods, either by using their online order form, or maybe sending them an example to duplicate. They're located in Redmond Oregon- - - -maybe somewhere close to you? Good luck!
1 Offline
Originally Posted by panic
... but remained silent when I posted the correct dimensions.
so you deleted the post were you posted the correct dimensions, or edited them out?? just confused why you would do either. headscratch
WW2Chevy
1942 Chevrolet G506 1-1/2 ton 4x4 Army Cargo w/ winch
(Retro-roco)
Panic must be thinking of a different post.
I posted the lengths of 216 and 235 pushrods almost at the beginning.
10.625” is the correct size.
My Blog
H Online: Content
Flagellation of a room temperature equine is so much fun!
LOL! nanner
AD Addict & Tinkerer
Gentlemen, we’re here to help! Lets get back on course and help this bolter!
Phil
Project Journals
Stovebolt Gallery Forum
I have a box full of the 10.625s NOS, if you are in need send a PM.
1946 1/2-Ton Chevy
MDReed #1495726 04/07/2023 10:26 PM
I suggest you examine the rocker arm adjuster balls for signs of eccentric wear. A narrow circular pattern close to the bottom may indicate replacement.
