5 members (Hotrod Lincoln, Otto Skorzeny, HandyAndy, Guitplayer, Hush), 151 guests, and 1 robot.
Topics128,034
Posts1,055,540
Members48,425
#1494432 03/29/2023 4:29 PM
I have a 57 with a 235 and the 4 speed automatic the CAM number is 3836330 so lifters appear hyd and
reading information a automatic should have been hyd so does anyome know for sure what cam I have ?
thanks
52-Mobil #1494436 03/29/2023 4:41 PM
H Online: Content
Chevy passenger cars with Powerglide automatic transmissions had hydraulic lifters. Post the stamped engine number on the machined pad behind the distributor, (not the block casting number) and we can tell if the engine is original to the truck. Trucks with the 4 speed Hydra-Matic ran solid lift cams. One of our resident number crunchers should be able to check that part number and confirm whether the cam should run solid or hydraulic lifters. Is that number something that's on the cam itself, or something you've found in a factory parts list? If it's a casting number, it's possible the same cam core was used for both hydraulic and solid lift camshafts.
52-Mobil #1494482 03/29/2023 10:34 PM
52-Mobil,
Based on some quick research, the number you provide "3836330" correspond in the Chevy Master Parts Catalogs as a "Generator brace" Group 2.317 for 6 cylinder engines. Not a correct "GM Part Number" for the cam in question.
Some further digging (see screenshot pics below from the 1929-57 Master Part List Catalog) shows that for the '56-'57 6 cylinders in Commercial and Utility Trucks, there was a cam that has a casting number of "3836390". Is it possible the number you see on your cam is this one??? If you can provide a picture, it would help determine yay or nay.
Beyond that, the book does not describe the cam as hydraulic lifter or solid lifter. But, looking at the listing for the "Lifter" (tappet) data, the corresponding '56-'57 Commercial and Utility Truck selection indicates the use of a 2-piece solid lifter (not hydraulic). The only listing for hydraulic lifters refers to Passenger vehicle engine applications.
Others will surely chime in here with more details or info I am not aware of (not all info is found in just these books), but this may help answer your question.
Dan
~ Dan
1951 Chevy 3 window 3100
52-Mobil #1494491 03/29/2023 10:56 PM
H Online: Content
If you have a set of V blocks, a dial indicator, and a degree wheel, there's a method of measuring the ramp between the base circle of the cam lobes and the actual valve lift area that's noticeably different between a solid lifter cam and one for hydraulic lifters. Send me a PM and I can provide some ballpark figures to look for on both styles of camshafts.
We popped the retainer from the lifter removed the “cup” ? Nothing inside so solid ?
52-Mobil #1494739 03/31/2023 9:10 PM
And this engine was light green and everyone says it’s supposed to be gray ? I have seen 2 grays light and darker so now what
52-Mobil #1494744 03/31/2023 9:48 PM
52-mobil That looks like 261 green paint,doesn't "mean" anything once that head gasket is taken off look for 261 vent holes six of them between cylinders. If you have those that is the wrong head gasket, also look for captains bars and large full floq oil filter holes on the drivers side. The head could be the wrong one too if not drilled for those vent holes. Read on stovebolt how to recognize all of that,if 261 3 3/4 inch bores or bigger.
52-Mobil #1494745 03/31/2023 9:53 PM
52-Mobl,
Looks like that casting number in your 2nd cam pick matches the "3836390" number from the catalog data.
The Engine Serial# data decodes as:
F = Flint
II = November (The capitol "I" was used do indicate the number "1" - so II equals the 11th month)
20 = 20th day of the month (November)
HD = 3100-3200-3600-3800-4000 series trucks with RPO (Regular Production Order) #s 308-314 (see below screenshot that denotes codes 308-314 all apply to "Automatic Transmission equipped trucks, with "314" specific to 3000 Series trucks equipped with Hydramatic tranmissions)
The debate on the correct color for your '57 engine has been discussed/debated a bunch. There are a whole slew of previous conversations that you can find using the "Search the Site" tool to read up more on that topic.
Hope this is of some help.
Dan
Engine Serial Number data 1957-Chevrolet-Truck.pdf.png (235.6 KB, 45 downloads)
Engine serial number data
~ Dan
Gdads51 #1494763 04/01/2023 12:51 AM
