2 members (Otto Skorzeny, 1 invisible), 92 guests, and 2 robots.
Topics128,031
Posts1,055,433
Members48,422
#149450 12/14/2006 6:27 PM
Good Morning. I bought and started working on '48 Chevy 2-ton flatbed about a month ago. Thanks for having this site as it's provided alot of usefull and inspirational information. Somewhere along the line someone put a '56 235 in the truck and my question is this. Since truck engines sit relatively level was there a stock intake manifold that did not have the elevation offset in it so that the carb sat level too?? Thanks for all your help.
1948 Chevy 6400
1964 Chevy 1/2 Ton
#149451 12/15/2006 4:53 AM
Welcome to the list!
I'm not real sure I know what your asking...to the best of my knowledge the car and truck motors all sit at almost the exact same angle, slightly lower in the rear, not level.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
#149452 12/15/2006 5:43 AM
Hi Mike, thanks for the reply. I see what you are saying, but my engine sits pretty level to where the carb is tipped forward. Maybe the engine mounts on the front need shimmed up. I don't think it hurts anything... I was mostly curious, plus the air cleaner would look nicer if it was level. Thanks.
1948 Chevy 6400
1964 Chevy 1/2 Ton
#149453 12/15/2006 7:37 AM
a 56 235 mounts differently than a 48 ... whoever put the engine in may not have rigged the front mounts properly
#149454 12/17/2006 12:21 AM
Thanks for the reply Bill. I'll look at it more closely to see what was done. Maybe I can shim it up to where it should be.
1948 Chevy 6400
1964 Chevy 1/2 Ton
